Arnold for 3ds Max
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Arnold Denoise AOVs not writing correctly in GPU mode for Maya 2022
1 REPLY 1
danthompson616
569 Views, 1 Reply
In Maya 2022 (in GPU mode) the variance filter AOV output drivers don't appear to write out to the exr. You can verify this by adding a view meta data node in nuke on the exr. If you compare the meta data to another exr that was rendered from arnold with CPU instead of GPU you will see the differences. I'm hoping Autodesk will fix this soon 😞
Tags (2)
Labels (2)
1 REPLY 1
thiago.ize
in reply to: danthompson616
This is a known limitation as we haven't yet finished porting all CPU features to GPU: https://docs.arnoldrenderer.com/display/A5ARP/Supported+Features+and+Known+Limitations.
  • Noice is not supported with Arnold GPU renders (because the variance filter is not supported on Arnold GPU)
