Arnold for 3ds Max
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Arnold 5 subsurface and normal map
4 REPLIES 4
ilai13
1660 Views, 4 Replies
hello,
I am attempting to create a realistic looking skin shader using aiStandartSurface, however when I take the subsurface weight up i seem to lose a lot of my normal map detail.
here are the different results and my hypershade - https://imgur.com/a/hEqdH
what would be the best way to retain the small details of the normal map while adding a good amount of subsurface?
thanks.
Labels (3)
4 REPLIES 4
gryphiz
in reply to: ilai13
You can play with Anisotropy to bring back some details or
Use cavity map or Displacement if it's possible.
ilai13
in reply to: ilai13
I tried both Anisotropy and Displacement and it does not seem to work.
however i did find out i can gain back the detail by bumping my IOR way up as you can see here - https://imgur.com/a/CJlfz
so i guess the IOR is effecting the subsurface?
Vstanish
in reply to: ilai13
I have the same problem!
Here is the doc to show.
Seems like SSS washes out the detail.
maxtarpini
in reply to: ilai13
