Arnold for 3ds Max
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Animated Image in Arnold 3ds Max
2 REPLIES 2
osukas
140 Views, 2 Replies
Hello, Im doing a texture where im loading an animated sequence.
Normally I would use the "Bitmap" node that easily makes a bitmap sequence, but i have to use the "Image" node instead because I will share this file with another artist using Arnold in Houdini, so I need to make our shaders compatible.
I googled and I saw that option in Maya, the use file sequence option, I can´t find it on MAX
Labels (3)
2 REPLIES 2
Stephen.Blair
in reply to: osukas
MAXtoA converts a Bitmap node to an Image node when you export an ass file.
// Stephen Blair
// Arnold Renderer Support
osukas
in reply to: Stephen.Blair
I used a bitmap loading a .ifl file for my image sequence, exported the .ass and indeed changed the BITMAP to IMAGE, but I lost the image sequence and is only reading frame 008
