Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Rendering Animation - Time goes up
3 REPLIES 3
CiroCardoso3v
376 Views, 3 Replies
So, the first frame is 20 minutes, and 8 hours late, the frame now takes 1 hour. The scene doesn't change, meaning that I don't have more geometry appearing, but the camera is moving slowly. No, I can't render using Kick as I am using Forest Pack.
I am still rendering with Arnold 6, because Arnold 7 isn't supported yet by Forest Pack. What worries me a lot is that this is just a preview, the real animation takes 1 hour per frame. So please I really need a solution for this.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Tags (1)
Labels (1)
3 REPLIES 3
I will try to provide some logs later.
Ciro Cardoso
I wonder if you can repro the slowdown with a smaller forest? That would make it easier to get logs and do some testing.
Are you rendering on the command-line with 3dsmaxcmd?
Usually, if you export to ASS with Expand Procedurals, that should work (unless there's something wonky about Forest Pack, which could be possible, I seem to remember getting invalid ass files)
// Stephen Blair
// Arnold Renderer Support
Thanks Stephen for the reply. I will do a couple of tests this weekend. I am opening 3ds Max and press render. I was afraid that the 3dsmaxcmd would case the same error of some of the assets not being fully supported.
So, if I export expand procedurals I could render ASS files? I didn't know that. There were a couple of time, where I forgot to instance the FP and got some error messages when I rendered later.
Ciro Cardoso
