Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
rebuilding beauty pass from AOV's...using Nuke
2 REPLIES 2
3488 Views, 2 Replies
Hi
I feel like this question has been asked and answered numerous times on these forums, but I'm still having trouble.
I am trying to rebuild my beauty pass using AOVs, comping in Nuke.
I render a Direct, Indirect, SSS, Specular, and Coat.
Using an Arnold standard material, my test beachball has a rough specular at 1.0, SSS at 1.0, Clearcoat at 1.0, and is being lit by an environment HDR map and a single point Arnold light.
I add them all together in Nuke (simple additive comp) and....it looks different from my beauty pass. Not very different, but different.
Does anyone know a good AOV workflow that rebuilds a beauty pass correctly, that gives me control of indirect, direct, specular (I can do without that one) clearcoat, and SSS?
Hi
Tags (3)
Labels (3)
2 REPLIES 2
lee_griggs
lee_griggs
Hi Matthew, from the AOV docs:
"Some example sets of additive AOVs for the full beauty AOV are:
  • direct, indirect, emission, background.
  • diffuse, specular, coat, transmission, sss, volume, emission, background.
  • diffuse_direct, diffuse_indirect, specular_direct, specular_indirect, coat, transmission, sss, volume, emission, background."
There is also a section in this tutorial that covers it. It is in Photoshop but should translate to Nuke.
Lee Griggs
Arnold rendering specialist
AUTODESK
Lee Griggs
AUTODESK
CiroCardoso3v
CiroCardoso3v
Hi Matthew,
see if this template will help you
https://we.tl/t-CjG4imSEqZ
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Hi Matthew,
Ciro Cardoso
