Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Projected Decals like Unreal and V-ray
3 REPLIES 3
teratron
636 Views, 3 Replies
Is there any way to project a material onto a mesh and/or multiple meshes without changing the material of those meshes or messing with their UVs? Ideally with the ability to only effect certain channels, I.e. only project a normal map onto a piece of metal so it's base color/roughness showed through. Or say I wanted to project a mossy decal across a few different rock meshes and have the normal map for the rock meshes blend with the mossy decal normal.
We do this allot in Unreal and it's awesome.
The best I can think of is a conforming mesh with transparency, but this is obviously problematic in workflows, and doesn't pass through the underlying material channels.
Thanks!
Tags (1)
Labels (1)
3 REPLIES 3
lee_griggs
in reply to: teratron
I presume you have tested the following shaders?:
mix shader
mix_rgba
layer_rgba
Lee Griggs
Arnold rendering specialist
AUTODESK
teratron
@Lee Griggs Thanks, yeah I'm familiar. I don't know of an easy way with those to have your decal project across materials/meshes. Say I had a brick wall with metal ducts and rubber wire meshes on top of it, and I wanted to spray-paint over everything. It would be allot of material and UV work to get that working.
With a projected decal it just works quick and easy. Some examples.
https://youtu.be/PjZEDzQuan0?t=84
https://youtu.be/5kzR_TdMGU4
lee_griggs
Maybe the uv_projection could help?
Lee Griggs
AUTODESK
Technology Administrators
