Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Problems exporting Arnold 3dsmax shaders to Maya
2 REPLIES 2
osukas
327 Views, 2 Replies
Hello, Im exporting a model from 3dsmax to Maya as .fbx
The artist told me to export the shader as a .ass
when i do it i get this warning, even when I used only Arnold maps
maya import all the maps but the nodes are broken, so he has to reconnect it manually, for a small shader that isnt a problem, but for bigger one could be very messy. Is tehre somethign im doing wrong here?
thanks
Labels (4)
2 REPLIES 2
CiroCardoso3v
in reply to: osukas
I did a quick test on my side. So in 3ds Max you export the material using the Archive tab
Then, in Maya if you go to the menu Arnold - Import Shaders
This is what I got
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
osukas
in reply to: osukas
wow thanks you a lot 😄
Technology Administrators
