- Mute
- Permalink
- Report
I have had a problem with material previews in the material editor, ever since I started using Arnold for 3Ds Max. Using the material editor effectively is proving challenging due to the fact that most maps I need to use won't show me a preview of what I'm doing (bitmap and standard surface displays a preview).
I can see the result of what I'm doing in the material I'm working on, but the results are very unpredictable when I can't view the inputs individually.
Show Shaded Material in Viewport also won't work with the same maps that don't show a preview in the material editor. Bitmap will work fine, but Image will not.
Auto Update is on, and Update Preview does nothing.
I had the same problem at home as here at work, which leads me to believe that there might be some setting I'm missing here... but I find it odd that a google search turned up nothing.
Anyone have an idea of what might be the problem?
MAXtoA version 2.0.937
3Ds Max 2018 - 20,0 - 20.0.0.966
