Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
MAXtoA denoising aovs with noice
8 REPLIES 8
Message 1 of 9
teamSP26J
673 Views, 8 Replies
Hi, I found this article https://arnoldsupport.com/2020/09/21/maxtoa-denoising-aovs-with-noice/
describing how to denoise AOVs. What I don't understand is if i still have to use the output denoising AOVs from the Denoiser render setup tab. Or that one is only for the beauty denoising.
8 REPLIES 8
Message 2 of 9
CiroCardoso3v
in reply to: teamSP26J
You can use my script to create those AOVS
https://github.com/CiroCardoso/CiroCardoso/tree/main/3dsMax/AOVWizzard
Basically, the way it works is that you create a mirrored version of the AOVs you want to denoise but you set the filter to Variance
So you have two files.
One EXR has the rendered AOVs the other EXR file has the information for each AOV to be denoised.
Then you go to this folder - C:\ProgramData\Autodesk\ApplicationPlugins\MAXtoA_2023
And a quick tip to  load the Command line is to select the path, type CMD and press enter
then in terms of the command line it works like this
C:\ProgramData\Autodesk\ApplicationPlugins\MAXtoA_2023\noice.exe
-ef 2 -sr 2 -pr 2 -v 0.5 (this are the noice settings)
-i %IMAGES%/AOVs0003.exr (this loads the EXR with the AOVs)
-i %IMAGES%/variance0003.exr (this loads the EXR with the variance info to denoise the AOVS)
-l diffuse -l specular (this is used to load the AVOs you want to denoise, like diffuse_indirect, etc)
-o %IMAGES%/denoised_AOVs0003.exr (and this to save the output to a specific location)
Another quick tip is if you drag and drop the exr file in the cmd window, it will automatically pick up the file's path.
Do not delete the N, Z and diffuse_albedo that my script creates, you need those AOVs for denoising.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 3 of 9
teamSP26J
in reply to: CiroCardoso3v
Thank you for this explanation. Few more questions. Should I denoise all the AOVs ? Even Z and cryptomatte so they match with the rest of the denoised passes?
Also how does the command change when I want to use this for a sequence?
Message 4 of 9
CiroCardoso3v
I believe you have to play around with the -f. The other thing is that the -ef is important so that you have temporal stability. Also, keep in mind that if you are rendering an animation you should have the Lock Sampling Pattern ticked.
No need to denoise cryptomatte, Z and or N. So anything that is DATA doesn't need to be denoised.
Ciro Cardoso
Message 5 of 9
teamSP26J
thanks again, really helpfull
Message 6 of 9
teamSP26J
So for denoising sequence of AOVs I did following. Rendered my sequence with all the AOVs I use and second sequence with AOVs and variance filters that I want to denoise (no need to denoise data AOVs). Look at how  CiroCardoso3v setup his. Then I ran these commands.
set IMAGES="path to my sequences"
set ARNOLD_BIN=C:\ProgramData\Autodesk\ApplicationPlugins\MAXtoA_2023
%ARNOLD_BIN%\noice ^
-ef 2 -sr 9 -pr 3 -v 0.5 -f 100 ^
-i %IMAGES%\myImage_0000.exr ^
-i %IMAGES%\variance_0000.exr ^
-l diffuse ^
-l specular ^
-l transmission ^
-o %IMAGES%\myOutput_0000.exr
-f defines how many frames to process and _0000 in the -i name defines from which frame to start
so my understanding is that if you want to cancel denoising and then start again (50/100 rendered), you run it like this (-f 50 ; _0050)
-ef 2 -sr 9 -pr 3 -v 0.5 -f 50 ^
-i %IMAGES%\myImage_0050.exr ^
-i %IMAGES%\variance_0050.exr ^
-l diffuse ^
-l specular ^
-l transmission ^
-o %IMAGES%\myOutput_0050.exr
If you have any improvements on this workflow or I do something wrong, let me know. It takes 3 minutes on 12 core machine to denoise one frame with this setup. Wonder if it is too long.
Message 7 of 9
CiroCardoso3v
3 minutes per frame sounds reasonable. Are you rendering HD?
Ciro Cardoso
Message 8 of 9
teamSP26J
yes, it is full HD
Message 9 of 9
CiroCardoso3v
Yeah, 3 minutes isn't too much. Now, is up to you if you want to increase the samples in the render and skip denoising or denoising just the AOVs with noise, which usually is the indirect AOVs.
Ciro Cardoso
Technology Administrators
