Announcements
maxtoA 5.0.0.93 failed to initialize on Max 2020 error code 106
10DSpace
10DSpace
I updated Max 2021 with MaxToA 5.0.0.93 without any problem. However MaxToA for Max 2020 did not install properly in Max 2020 on my machine. When I started Max 2020 after the maxtoA 5.0.0.93 install, I received an error message that "C:\ProgramData\autodeskapplication..........MaxtoA.dlr failed to initialize. Error Code 126 The specified Module could not be found." After dismissing the error code dialog box I go the same message for MaxtoA_Menu.gup. And of course, While max eventually started up, Arnold was not an available render option. However, when I checked the path for both .MaxtoA.dlr and MaxtoA_Menu.gup , both files were in the directory they should be in. I tried rebooting my machine, but got the same result.
I installed the previous version of MaxtoA 4.3.4.12 in Max 2020 which works fine. This may be a an installation bug?
Stephen.Blair
Hi
Please try this:
  • Uninstall MAXtoA (from the Control Panel)
  • Check that C:\ProgramData\Autodesk\ApplicationPlugins\MAXtoA_2020 was removed
  • Install MAXtoA 5.0.0.93
That worked for me.
// Stephen Blair
// Arnold Renderer Support
10DSpace
Thanks, Stephen. That worked and it was obvious enough as a possible solution that I should have tried it to begin with. Out of curiosity, it is known why the ver 5.0.0.93 installer worked for Max 2021 but not Max 2020?
Stephen.Blair
Hi David
No, and I've logged a bug for this.
// Stephen Blair
