maxtoa 5.0.0.93 crashes
All kinds of problems with new release. I cannot get to render my existing files correctly. Here is a simple render of a cabinet and the Render Messages I am getting:
SYSTEM: Production renderer is changed to Arnold. Previous messages are cleared.
[Arnold]: 00:00:00 1857MB WARNING | [color_manager_ocio] unable to find default OCIO config, expected in c:\programdata\autodesk\applicationplugins\maxtoa_2022\..\ocio\configs\arnold\config.ocio
[Arnold]: 00:00:00 2069MB WARNING | [AiMakeTx] prep 0.00s (3.3 GB)
Reading file: C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.bump.jpg
read "C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.bump.jpg" 0.01s (3.3 GB)
misc2 0.00s (3.3 GB)
pixelstats 0.01s (3.3 GB)
misc2b 0.00s (3.3 GB)
Converting from colorspace sRGB to colorspace scene-linear Rec.709-sRGB
color convert 0.05s (3.3 GB)
misc3 0.00s (3.3 GB)
resize & data convert 0.00s (3.3 GB)
SHA-1: 82D659C24FC52BAE76222AAF0D17231F0DBE5A45
SHA-1 hash 0.01s (3.3 GB)
AverageColor: 0.624439
misc4 0.00s (3.3 GB)
maketx run time (seconds): 0.07
file read: 0.01
file write: 0.00
initial resize: 0.00
hash: 0.01
pixelstats: 0.01
mip computation: 0.00
color convert: 0.05
unaccounted: 0.05 ( 0.00 0.00 0.00 0.00 0.00)
maketx peak memory used: 3.3 GB
make_texture ERROR: Could not open "C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.bump.8276c284.temp.tx" : Could not open "C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.bump.8276c284.temp.tx"
[Arnold]: 00:00:00 2063MB WARNING | [AiMakeTx] prep 0.00s (3.3 GB)
Reading file: C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats\Brick_Non_Uniform_Running_bump.png
read "C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats\Brick_Non_Uniform_Running_bump.png" 0.02s (3.3 GB)
Monochrome image detected. Converting to single channel texture.
misc2b 0.01s (3.3 GB)
color convert 0.04s (3.3 GB)
SHA-1: E5C5C54075CDD3965C1160487E4229074E677B34
AverageColor: 0.392567
maketx run time (seconds): 0.09
file read: 0.02
file write: 0.00
hash: 0.01
pixelstats: 0.01
color convert: 0.04
unaccounted: 0.06 ( 0.00 0.00 0.01 0.00 0.00)
make_texture ERROR: Could not open "C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats\Brick_Non_Uniform_Running_bump.933ec42e.temp.tx" : Could not open "C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats\Brick_Non_Uniform_Running_bump.933ec42e.temp.tx"
[Arnold]: 00:00:00 2051MB WARNING | [AiMakeTx] prep 0.00s (3.3 GB)
Reading file: C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.jpg
read "C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.jpg" 0.01s (3.3 GB)
SHA-1: 130C6BBC0BAF69FB662C14730072F4FB5524CB50
SHA-1 hash 0.02s (3.3 GB)
AverageColor: 0.485544,0.498556,0.495245
file read: 0.01
file write: 0.00
hash: 0.02
pixelstats: 0.01
color convert: 0.05
unaccounted: 0.06 ( 0.00 0.00 0.00 0.00 0.00)
make_texture ERROR: Could not open "C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.447c071e.temp.tx" : Could not open "C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.447c071e.temp.tx"
[MAXtoA]: [maketx] Could not convert the texture to TX, original texture will be used 1/4: 'C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats\Brick_Non_Uniform_Running_bump.png'
[MAXtoA]: [maketx] Could not convert the texture to TX, original texture will be used 2/4: 'C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.bump.jpg'
[MAXtoA]: [maketx] Could not convert the texture to TX, original texture will be used 3/4: 'C:\Program Files\Autodesk\3ds Max 2022\Maps\Concrete.Cast-In-Place.Flat.Broom.Grey.jpg'
[Arnold]: 00:00:00 2308MB WARNING | [color_manager_ocio] could not find a valid config
[Arnold]: 00:00:00 2360MB WARNING | opaque is deprecated: opaque is off for geometry "", but there is no opacity metadata for some of its shaders
[Arnold]: 00:00:01 2418MB ERROR | [texturesys] OSL get_texture_info(): Invalid image file "D:\Remodeling\3ds Max\Cabinetry\Primary\Wood Grain Texture.tif": image was untiled
[Arnold]: 00:00:01 2424MB ERROR | [texturesys] OSL get_texture_info(): Invalid image file "D:\Remodeling\3ds Max\Cabinetry\Primary\Wood Grain Texture.tif": image was untiled
[Arnold]: 00:00:01 2427MB WARNING | Aborted by user: received abort signal
