Announcements
(Max to A) ERROR: Map# 241 : Bitmap has an empty filename.
Sandra.Massa
Sandra.Massa
I have the latest version of Arnold Max to A etc...
computer is certified ISV laptop Lenovo p73 with quadro rtx 5000 etc...,
Every time I open up my 2019 3ds Max created Arnold Library
1st I see all of my materials to QUICKLY turn black and the error message says for each Map in Arnold Material Library:
Map #... Bitmaps: Bitmap has an empty filename.
Please advise and Or FIX.
Sandra
Stephen.Blair
Are there bitmaps with no file name? What version did you use to create the material library? Can you upload a material library with just one material that shows the problem?
// Stephen Blair
// Arnold Renderer Support
Stephen.Blair
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Did you see this KB article? Is it the same issue?
// Stephen Blair
CiroCardoso3v
I had this issue, runned the Scene Converter and use the Remove Missing Bitmap. It worked for me.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
