Light distribution problem
Why do i get this dark area?
- Checked the normals - they are ok!
- Diffuse bounces high
The scene is lit with a HDRI Image.
To get this dark area lighten, i have to place an extra light and cranck it up hard(of course that´s not what i want)
Thanks for your help! Greets!
Maybe this is physical correct but it looks weird.
Replies (8)
lee_griggs
Are the interior normals correct?
Lee Griggs
Arnold rendering specialist
AUTODESK
yes the normals are correct
lee_griggs
What is the specular ray depth? If that doesn't do it, can you upload the scene somewhere?
Lee Griggs
AUTODESK
test1.zip
This is the file, i cant upload the hdri image(filesize to big)
studio_Render__EricdesignReflection_small.zip
Small version of the hdri map
lee_griggs
There seems to be something wrong with the geo. When I rotate one of the sides it renders fine.
Lee Griggs
AUTODESK
madsd
There are a couple of things going on here.
You have set Specular rays to 4. Increase this to 10.
You are not letting enough specular rays in, and it darkens the tunnel area.
Doing 10 specular or around will raise the brightness of the interior.
You also have 1.0 in Metalness, if you decrease this to 0.9 or 0.95 you let more birghtness in as well.
I dont get a fully black interior when I load your scene, so make sure you have the latest version of arnold install as well.
The nature of this tunnel will make it darker than the exterior but with above tweaks I can make it look much brighter without having to solve a mesh normal issue.
I will try this out, thx!
