How to switch back to the old Maya render view?
Parmenides
Parmenides
I upgraded to 5.2 and when I hit the 'Render the current Frame' button it switches to Arnold Renderview instead.  We don't use the Arnold RV button as it is way too buggy. Often doesn't update or show changes in blend shapes or instances. The regular Maya render view almost always works as expected and often if you hit that then you can reset the Arnold one.  Now there is no way to get a clean render without quitting/reopening.  How do I switch back?  Thanks.
Stephen.Blair
IPR in the Maya Render View updates, but Arnold Render View doesn't? They are both using the same code, so that doesn't sound right. If the Maya Render View is automatically updating (eg you don't have to click the Refresh icon) to show changes, the Arnold Render View should do the same.
What kind of changes on instances? shading or geometry?
"No way to get a clean render..." Not even Scene Update?
// Stephen Blair
// Arnold Renderer Support
Parmenides
Apparently this means we can't switch back.  For such a small point upgrade, this has been disruptive to our workflow.
It appears that not options that were in the old render window are in the new/only Arnold render window. For example before if you go to save an image there was an option to choose what image format you want, now it just saves it as .jpg. Unless there is some unintuitive place it has been moved to.
In the past we didn't use the IPR in the Maya Render window, so if they use the same code it didn't apply.  We would use the Arnold IPR and when things get strange, instance meshes disappearing or deformations not showing the deformed state, we would hit the Maya render button and it would be fine.  If it happens again I will get screenshots.
thiago.ize
I'm not too experienced with Maya, so I might be completely off here, but what happens if you try to save it with the file extension you want? For instance, name it "foo.exr" (ignore that it says jpg). Does that work?
Parmenides
Hey, that worked for the saving issue. I really thought that it would just append it, ie: foo.exr.jpg.  One issue out of the way. Thanks!
mickymartin1542
Observer
Observer
Go back in the view history.Press [
Go forward in the view history.Press ]
How do you get to the front view in Maya?
In a view panel, select Panels > Perspective > New or Panels > Orthographic > New. Note that the back, bottom, left, and right cameras are available from this menu, in addition to the front and top cameras.
How do you switch the view to the camera one?
On Android:
  1. Open the Meet mobile app.
  2. Join a video call.
  3. On the top right corner, tap Switch camera .
How do I change perspective view from top to left?
Click or right-click the Point-Of-View (POV) viewport label. > Point-Of-View (POV) Viewport Label Menu > Choose Perspective or Orthographic. You can also choose a specific orthographic view such as Front, Top, Left, Right, and so on.
How do I reset the camera view in Maya?
Reset the perspective camera:
  1. Delete all unnecessary cameras in the Outliner.
  2. In the four panel Viewport view (default), select an object and press Shift + f.
  3. In the Perspective Viewport, select View, Select Camera.
  4. Navigate to Modify, Reset transformations.
How do I see camera view in Maya?
To look through a selected camera, click Panels > Look Through Selected (this also works with objects). To look through another camera, click Panels, then select the camera name from either the Perspective or Orthographic submenus.
How do I switch between zoom cameras?
Switching cameras Tap the camera name to select a camera, which immediately becomes active. You can do this any time you want to change the active camera. If two cameras are available, the currently inactive camera becomes active. Tap the Switch Camera control any time you want to toggle between them.
How do I change user perspective?
1 Answer. Just hold middle mouse button and drag to rotate the view. The 5 on your Numpad switches between perspective and orthographic view. Numpad 0 switches into Camera view.
How do I change the view in blender?
Using the Ctrl+Alt+Q hotkey, you can quickly switch between Blender’s regular viewport and a Quad View viewport like some other 3D programs have. When toggling back to Full View from Quad View, Blender chooses the view that your mouse cursor is hovering over when you do the switch.
What is viewport in Maya?
Viewport 2.0 is the viewport and hardware renderer in Maya – it’s the way you view your scene.
How do you change the brightness in Maya?
Double-click the light icon in the Hypershade light tab or work area, and adjust its values in the Hypershade Property Editor. Select the light in the Light Editor and adjust its values in the Light Editor Property Editor.
How do I switch between cameras in Maya?
If the Viewcube is not displayed, click Renderer found next to the Panels tab and select Legacy Default Viewport to display the Viewcube. On the Viewcube click, hold and move the left mouse button to change the perspective by hand. Right-click to access additional menus. The small arrows change the view direction.
Can I use 2 webcams at the same time Zoom?
Like the Zoom desktop application, Zoom Rooms can share a second camera, to allow using two cameras at the same time from a Zoom Room.
read more
