Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
How can change via maxscript the output path and AOV output path?
2 REPLIES 2
332 Views, 2 Replies
Hi, im making a script to configure multiple passes with diferent render engines, and the only limitation i have is to change the outputs in arnold, on scanline, vray and corona y use te standar "rendOutputFilename" Method but dont work with arnold, this trow an error. tahnks
Tags (1)
Labels (1)
2 REPLIES 2
Stephen.Blair
Thanks Stephen, but o don't want to create the aovs, i only want yo change the output path of already created ones.
Technology Administrators
