Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Fast patterned glass for interior
5 REPLIES 5
521 Views, 5 Replies
So on this tutorial of Blender Guru at 5:10 (Or 6:46 I think) you can see it, basically he uses the light path node so he can pass light throught glass and make it render fast. This would allow to render glasses with some kind of pattern like this https://i.pinimg.com/originals/0c/0e/4d/0c0e4dfc2cf599d06fd88ac79fe7ad98.jpg
I need to know cause in class I have to use 3DS Max and it comes with Arnold.
Tags (1)
Labels (1)
5 REPLIES 5
lee_griggs
Where is the video link? Have you tried using a displacement or bump (far distance)?
Lee Griggs
Arnold rendering specialist
AUTODESK
Here's the video https://www.youtube.com/watch?v=I685JGTCpCU
The problem is not how to do it, but how to do it fast, as you can see, light there can only pass through glass, but that makes the render time ridiculously high, the glass has to be transparent for the scene but only visible to the camera.
You could try trough the Arnold properties modifier: adjusting the general properties and/or light group.
Oh, that seems interesting, not sure how I'll set up that yet, but the arnold manual says it's not currently working, at least in the latest version, I tested it and didn't notice any time or appearance difference.
https://support.solidangle.com/display/A5AF3DSUG/Lights
They appear also here, but nothing is said about if it's aviable or not https://support.solidangle.com/display/A5AF3DSUG/Light+Group
lee_griggs
Have you tried using a Ray Switch shader?
Lee Griggs
AUTODESK
