AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Denoise correctly with imager denoiser noice
pproestos
Message 1 of 13
pproestos
I want to use imagers and is impossible to
work with denoise.
The final picture that produces is totally dark with no lighting.
Please any support for that?
thx
Something is wrong with the cameras.
When I clone a camera, some times the denoise works excellent.
Anyway if any dev want to see my whole max file I can send it to any email given to me.
Replies (12)
Message 2 of 13
CiroCardoso3v
Is this just on the Arnold Render View? The example you show does have light? When you are on the preview process the image can look brighter.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 3 of 13
pproestos
Ciro is has an environment hdri, two portals and three interior lights.
If I clone the camera, sometimes it works, I mean I have the bright
picture -the same when I start rendering- and at the end of rendering
wheyn applying imager denoiser noice it just eliminates the noise
but without alterating picture brightness.
This is the perfect scenario, just...is not happening for all cameras.
But...hmmm... you gave me an idea....
Maybe this is a bug because I don't use skydome and
using only environment map for skylight?
Now I am rendering and I must test it later...
For sure there is a huge bug here...
Message 4 of 13
pproestos
Allright I just disabled
and now everything works...
Message 5 of 13
madsd
That is not a solution.
I think it glitches because you use Both the old Exposure control and Arnold imagers, I have seen that it can pulse if both are on on some earlier builds.
Always use the ARV window, it is much better than Production or Active shade, you can work with Imagers directly in the window, you dont need to do anything in Slate with Imager nodes.
Do you have the absolute newest Arnold installed?
Message 6 of 13
pproestos
No Mads I don't use any of the old exposure.
In arnold renderview when I hook that denoise node,
the result is as I mentioned before, dark.
So in my previews I just dont use it.
But when in production render and especially
using batch rendering sctipts to open multiple max file
in a chain, it works correctly.
I just have to disable that parameter!...
Message 7 of 13
madsd
This works perfect.
So dont use the old environment panels exposure part at all.
I have zero flickering or highlights lost.
Message 8 of 13
pproestos
ok! Mads, I just cannot make your answer as solution, I dont see the button here...
Message 9 of 13
madsd
Something is wrong in your setup, if you need to disable this.
We need to find out what, so if you can minimize a reproducable case to a plane and a teapot and upload, then we can verify the glitch.
Else its a bug that gets a workaround and never gets solved, so if you could do that it would be great.
Message 10 of 13
pproestos
ok allow me some time and I'll do it
Message 11 of 13
pproestos
ok @Mads Drøschler please make test in render view with/without denoise noice...
and then a production render enabling/disabling "using for this scene" render view
https://we.tl/t-rM0kieBLdU
Message 12 of 13
madsd
Got the file.
The first thing I notice is that all the Imager nodes inside ARV are called "map"
ccc.pngThis indicates we are not using the same version of Arnold. I use the newest from the net.
Make sure you have this version installed, they recently fixed some issues regarding Imager fundamental glitches.
Download it here ->
https://www.arnoldrenderer.com/arnold/download/
Make sure you are always on the latest version of Arnold.
I will try your scene and see if I can provoke any issues with this build, try it yourself and see if that cleared the issue.
Message 13 of 13
pproestos
Mads
Here are my notes regarding IPR renderview and imager denoiser (noice)
that I've used since now from the moment they are introduced:
Anyway no matter if this a bug or not, I am completely happy because
after hours of testing, finally now I can run my batch file and imager
denoise perfectly
So to begin, the way I work is this:
1.Old method:
After finalize my scene, I create a separate file for
each camera in viewport.
So if I have five cameras, I create five max files and
then with a max script I render them in a chain with
a batch file script, all night.
After they finish, I denoise all my exr files with noice.exe
and put them in frame buffer to adjust their exposure settings ecc.
Since now that method worked perfect
2.New method:
The same concept as before, but now I no longer use
Environment exposure control and noice.exe to denoise.
Instead I use imagers and imager denoiser (noice)
So regarding the new method, what I noticed is:
A)
If I check Render setup->System->Arnold Render View->
Use For This Scene, every time max opens automatically
to render due to the batch script, there are a lot of times
that renders wrong camera or the same camera again and again.
Instead if I don't check to open IPR window and open the normal
production rendering window everything works perfect, means
that each max file, renders the camera that has in viewport.
B)
I usually use an HDRI file for skylight illumination.
If I use skydome and put this HDRI as texture, imager denoiser (noice)
works excellent.
Even if while rendering shows a darker image, at the end when
applying denoise image has correct illumination and no noise.
Bad things happens when I don't use skydome at all.
So in this situation I put the HDRI as environment map in
Environment and effects rollout window and of course
check "use map".
The result is that when applying imager denoiser, it
gives a noise free but a dark image with no correct
illumination I have setup initially.
So my conclusion is that to continue to work with
batch scripts and correct denoise, I must not check
the IPR window as default for new scenes and I must
not use environment map as skylight illumination but
only skydome.
***Also I noticed that those "Residual lights" parameter
in imager light mixer, if I turn it to 0 it gives not correct
dark image at the end of denoising. So it has to be 1
to work with denoise.
And here I want to thank Ciro @ who inspired me to
find the right solution, at list fot the way I render...
