Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
denoice.exe Animation Batch Script v0.1 for 3DS MAX download here.
3 REPLIES 3
madsd
1188 Views, 3 Replies
madsd
Here you will find a VERY early version of a batch script that can take an image sequence of properly created .exr files with N,Z,RGBA,Albedo_Diffuse and Variance filter layers as shown in instructions, and then convert the image range into denoised versions. So you need to change folder name, and the file name, and you can swap out the "100" with the actual frame number you got.
You need to save out this text bit into a Denoiser.bat file, you can create a .txt file and rename file and the extension afterwards. Do note you need to edit the file, you cant just run it.
I will ofcourse update it, and very likely create a small UI for max, with some settings at a point, but for now this has been tested and it works perfect in my end.
https://www.dropbox.com/s/dfrvgajpq0hy5ge/Denoiser.bat?dl=0
3 REPLIES 3
in reply to: madsd
Hey Mads
I have been pulling my hair out trying to get Noice denoising on individual AOV layers, since the latest MaxtoA update. I have managed to get the command-prompt solution working...but it's only for single images, not sequences.
Your script looks fantastic! However, (and only if you have time) can you let me know how you set up your AOVs to make this work?
Right now, I have one EXR containing all my components, (diffuse, specular, etc etc) plus my Denoise_albedo, Z, and N, then I have a second EXR containing the components I with to denoise, set to filter variance.
This works for command-line technique...but the command line technique requires both the main components EXR plus the variance EXR...your batch script only seems to call for one exr file (per frame) and that's it....so I feel I haven't set my AOVs up correctly.
Thanks again, and if you have not time to answer that's totally cool.
Stay healthy and safe!
-matt
Hey Mads
-matt
Stephen.Blair
Stephen.Blair
Can you post your full command-line for denoising a single image?
It's just a matter of updating that batch script with the additional arguments
// Stephen Blair
// Arnold Renderer Support
// Stephen Blair
Stephen.Blair
in reply to: madsd
Stephen.Blair
Here's an example. I updated to run this noice command line
@echo off
setlocal enabledelayedexpansion
SET "noice=C:\ProgramData\Autodesk\ApplicationPlugins\MAXtoA\noice.exe"
SET "MPath=C:\go\"
SET "MName=go"
for /l %%i in (1,1,100) do (
set "frame=%%i"
if !frame! GEQ 100 set "lframe=0!frame!"
if !frame! LEQ 99 set "lframe=00!frame!"
if !frame! LEQ 9 set "lframe=000!frame!"
 start /WAIT %noice% ^
-ef 2 -sr 2 -pr 2 -v 0.5 ^
-i %MPath%%MName%_AOVs!lframe!.exr ^
-i %MPath%%MName%_variance!lframe!.exr ^
-l diffuse ^
-l specular ^
-o %MPath%%MName%_Denoised!lframe!.exr
You have to add a -l for each AOV you want to denoise.
// Stephen Blair
@echo off
SET "MPath=C:\go\"
SET "MName=go"
set "frame=%%i"
-l diffuse ^
-l specular ^
// Stephen Blair
