Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Complex IOR in 3DS Max 2020
5 REPLIES 5
1048 Views, 5 Replies
Hi, I was learning about the Complex IOR shading in 3DS Max 2019 and then updated to 2020, now I can't find the node anymore. Using MaxtoA 3.2.57 here.
Tags (3)
Labels (3)
5 REPLIES 5
Stephen.Blair
Complex IOR is deprecated (it's old and you should not use it).
The Standard Surface has the complex Fresnel built-in when the metalness is > 0, using the base and specular color.
// Stephen Blair
// Arnold Renderer Support
kulaginb
in reply to: Stephen.Blair
Really? Is Metalness parameter gives us physical correct IOR? For some metals or alloys its not enough two colors falloff. Do you know about measured IOR?
Can anyone tell me if the node doesn't exist in the Arnold recent updates or if it is a problem with my 3ds Max version?
madsd
Try look at Stephen's reply.
Also ->
Thank you! And sorry, I really thought I had checked the docs. Plus, Boris' comment made me doubt about Stephen's reply so I needed one more.
Technology Administrators
