Car Paint anf Bump
Car Paint anf Bump
Hi!, I'm triying to render a carpaint shader with a bump, but I canĀ“t connect it. It's a limitation? thx!
Replies (8)
lee_griggs
How are you connecting it? There is currently a bug with Coat Normal.
Lee Griggs
Arnold rendering specialist
AUTODESK
Hi! I connect a normal map to "normal camera" in the shader, but don't have effect
lee_griggs
Coat Normal? Right that's broken. It should be fixed in a future release.
Lee Griggs
AUTODESK
Jordi_Garcƃ_a
I connect a normal map to ā€œnormal cameraā€ in the shader but donā€™t have effect
gryphiz
Same thing with MaxtoA.
Any news on when will the fixed version come?
arkitek62
any news about it guys ?
Jessica_V
Hi! I Use Arnol 5.1.0.1 and I have the same situation. I can plug the out Value of a aiBump2D in The normal Camera chanel of a aiCarPaint shader, but it did not affect my render. I try the same aiBump2D on aiStandarSurface and it work perfectly well. I wonder if it's a bug or if the bump need to be plug in a special way for the aiCarpaint Shader.
Stephen.Blair
Fixed in Arnold 5.1.0.0
Use the Coat Normal.
// Stephen Blair
// Arnold Renderer Support
