Would anyone know why when I try to set my Atmosphere Volume Density to below 0.01 it defaults to 0.0? I would like to try setting it to 0.001 but it resets it to zero. I would generally like to make the atmosphere volume less dense. Is this a units setting in Max somewhere? An issue or a known default in Arnold? Thank you!
That sounds more like a UI issue.
In Maya I can set the density to 0.0001 and it works. But the UI displays 0.000 for anything smaller than 0.001
Softimage was the same too
Like Stephen says, it's just UI.
I wrote a small shader that gives you a value of 10.0 as a starting point for 0.001.
So the shader sends out the value you want, if you lower the 10.0 to 1.0 you move to the 0.0001 area and so forth.
Just grab the code and compile it, or save it in a file called VolumeDensity.osl and save it in the OSL folder in Plugins under Max install path.
shader VolumeDensity ( float Density = 10, output float Density_out = 0, ) { Density_out = Density/10000; }
thank you Stephen! I'll do some fiddling to see if it returns a value even if it says 0.0
Go to Customize->Preferences, in the General tab set the Spinners' precision to the desired value. That setting should apply to all the floating point parameters.
It is showing zero but the atmosphere is still rendering, so the ui just isn't displaying the existing setting. Thanks!
