- Mute
- Permalink
- Report
Just updated to version: MAXtoA-2.3.37.2018.exe
Now it seems creating a new volume even when checking box adds no shader. recreating over and over and finally a volume shader is created..
Then original volume shader can't be removed and I end up with 2 shaders if I try to add a new one. If I apply the original shader it clears the 2nd but applying the second doesn't remove the first so it ends up with 2 - so I have no way to change the volume shader. Is this a feature?
Thanks in advance.
