Can a surface reflection ignore the physical sky?
I am working on a parody, and would like to recreate the Castle Rock logo: https://www.youtube.com/watch?v=O31jJ7I7qRI
If you look at the video, you'll see that the lighthouse beams move and illuminate the land, the lighting sort of comes up like a sunrise (as a sun actually rises)....
BUT....even though the water becomes more illuminated in general, it does not reflect the world in a normal way. The sun reflected seems larger, and the color and lighting of the water seems to be 100% independent of the sky/environment.
I get that this probably isn't an actual 3d render, but I'm wondering how much of this I can obtain via Max and Arnold. Any time I try a surface with a water-like shader, it (CORRECTLY) takes on the look of the physical sky.
Any advice....I'm THINKING it may involve rendering the water, then just compositing the above sea level bits....????
brian_Foley
You should probably be able to achieve this with the Ray Switch Shader.
https://support.solidangle.com/display/A5AF3DSUG/Ray+Switch+Shader
This looks like EXACTLY the thing! Thanks, Brian..... so would I be right in thinking that I could just save a bitmap to a Standard Shader (with the bitmap being the 'above sea level' lighthouse and land) and then pipe that shader to the reflection of the water?
brian_Foley
Apply the AIrayswitch to the skydome light.
I am a Maya user so I am not sure about the workflow but it should be nearly the same.
