Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Calculate a normal maps blue channel out of red and green?
1 REPLY 1
ACCCC
392 Views, 1 Reply
Hey, i have a couple of models that use 2 channel normal maps and have other data embedded into the blue and alpha channel. Is there a way to use 2 channel normal maps and calculate the Z value using the red and green channel?
If so how heavy would this be in terms of rendertime compared to simply using a value of 1 for the blue channel?
1 REPLY 1
madsd
in reply to: ACCCC
It will not affect render time. you are just routing some channels around in a different way.
Not entirely sure I understand, but you can split out the .x and .y channels do some addition of them, average, multiply them, do "anything" then add that to a vector in the 3rd slot, and pipe x and y to the first 2.
Since its max, maybe send over a plane with the setup you got and we can try look at it?
Technology Administrators
