Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Arnold toon shader
6 REPLIES 6
799 Views, 6 Replies
Arnold toon shader
1.pngHello. I started using Arnold recently in order to use built in toon shader. And i followed tutorials etc. but got different results than the person in the tutorial. I was copying it step by step, but it was for c4d and i work in 3ds max so some things were different. My question is, is there a way to assign toon shader to geometry other than by going through attaching it to base color of standard material? Can i somehow assign only toon shader without going through standard material? Like in the image i attached from one of the tutorials it just says assign toon shader to the gemotry but it won't let me do that unless i go through some material.
Tags (1)
Labels (1)
6 REPLIES 6
Stephen.Blair
I would use Map to Material
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
Can you elaborate? You mean doing like i said in my question is a good way of doing it?
lee_griggs
Yes, use Map to Material. I don't see any mention of 'standard' material in the tutorial?
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Map+To+Material
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Maps
Lee Griggs
Arnold rendering specialist
AUTODESK
Stephen.Blair
Like this:
// Stephen Blair
in reply to: lee_griggs
Ooh, thanks!
Ok i got it now, thank you very much!
