Arnold contour Filter renders image is transparent
Dear all,
I need your help.
I had add Toon material to the image, after rendering in Arnold the png image is transparent. I can see only some lines. I had changed the Filtering type to contour from default. I don't know about AOVs. Can anyone explain me through some pictures to make image clear like with lines can see
This is the image after rendering in Arnold and saving to PNG format
Toon Material added showing
Arnold Rendering Settings
Render image saved in BMP format
Please help me
Regards
Replies (19)
Please help me
Please help me. I don't know how to solve this issue
lee_griggs
Isn't that the alpha from the PNG that you are viewing?
Try rendering with a different file format.
Lee Griggs
Arnold rendering specialist
AUTODESK
Thanks Sir,
Aplha from the PNG is viewing at the top. I Saved in different file format, however image is not transparent. so its easy to work in Photoshop.
lee_griggs
Here is information about rendering edges separately.
Lee Griggs
AUTODESK
Sir,
I had seen this in the Arnold, But I don't know how to create RGBA AOV (beauty) and a Custom AOV (edges) . Can you please show some link for video to see how to create. Sorry Sir for the trouble
Regards
Deepu
lee_griggs
https://arnold-rendering.com/2020/05/22/maxtoa-rendering-aovs/
Lee Griggs
AUTODESK
Thanks Sir for the link. I will update you with the result
Sorry Sir, i failed again. In that link no where showing to edges and attaching to the materials. Can you please help me
Sorry Sir,
Really Sorry can you please share one 3d max sample file having beauty and edges
I am new in this. I know i am troubling you. Please help me
Sir
Can you please advice me whether this is the way to take custom AOV, however the output image doesn't have (lines) Toons at the edge but image is saving in PNG format.
Good morning
Anyone can help me regarding my issue
Can any one help me to solve my issue
CiroCardoso3v
Maybe this could help
https://we.tl/t-cGvGuXcWW1
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Dear All,
I need help from Arnold team. Please help me solve my issue. I added AOV's, however toon line is not coming in the output. Image is saving in PNG. Before Toon line is coming and not saving in PNG.
Regards
Deepu
lee_griggs
Check the workflow here. Also, I have updated the scene here with the AOVs for you.
Lee Griggs
AUTODESK
Thanks a lot. i will try to do today and replay back
Stephen.Blair
As suggested originally by Lee, don't use PNG. Try EXR or some other format.
// Stephen Blair
// Arnold Renderer Support
