Arnold 6 License Server Install failing
mpowers
mpowers
I am trying to update/ re-install both the network License server and our 2020 Arnold licenses for MAXtoA. I generated a new 2020 license on https://manage.autodesk.com/cep/#products-services/products/generate-license. But when I run "Install license server" from the ArnoldLicenseManager.exe it fails. I tried removing the old service using LMTOOLS but it still fails. I can send you the Installer.log and diagnostic off forum.
-thnx
#Stephen Blair
Mike Powers
Director of Animation \ Cramer
mpowers@cramer.com
https://vimeo.com/mpowers
3DBOXX W8920Processor 32.0 GB RAM
Dual Xeon CPU E5-2670 0 @ 2.60GHz, 2601 Mhz, 8 Core(s), 16 Logical Processor(s)
Windows 10 Enterprise - 1809
NVIADIA Dual RTX2080TI 11GB V 419.35
Stephen.Blair
Unless you have an old version of NLM, there was no need to re-install it.
Just start LMTools, point it to the new license file, and do a Reread (or maybe a Stop then Start).
// Stephen Blair
// Arnold Renderer Support
Stephen.Blair
If you stop the service, you should be able to install.
Open the Windows services console (search for services.msc), find the NLM service, and stop it.
Then run the installer.
// Stephen Blair
mpowers
I'm not sure what is happening, but when I use LMTOOLS:
Status
Flexible License Manager status on Fri 2/21/2020 13:26
[Detecting lmgrd processes...]
License server status: @Animation3
License file(s) on Animation3: C:\ProgramData\Autodesk\ApplicationPlugins\MAXtoA_2020\license\Animation36805CA0877D8.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: Animation3
License path: @Animation3;
FlexNet Licensing error:-15,570
Mike Powers
mpowers@cramer.com
Stephen.Blair
@ Please send your license file and the server debug log to support@arnoldrenderer.com
In LMTOOLS, the Config Services tab has the path to the debug log file.
// Stephen Blair
mpowers
No NLM listed in services
Mike Powers
mpowers@cramer.com
mpowers
I downloaded and installed new NLM. Service started. Thnx
https://knowledge.autodesk.com/customer-service/network-license-administration/get-ready-network-lic...
Mike Powers
mpowers@cramer.com
