Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
[4.2.2.20] noice doesn't works at all.
10 REPLIES 10
Message 1 of 11
RGhost77
999 Views, 10 Replies
RGhost77
Can someone confirm that Noice denoiser doesn't work in 4.2.2.20 MAXtoA?
Steps to Reproduce:
1. render any scene with "Output Denoising AOVs" (save to .exr using Render Output )
2. Use "image"_Noice_Input.exr with Arnold Denoiser (noice.exe also doesn't works)
Denoise not applied in output denoiser image.
p.s. I already submit bug report (DEFECT-3719) through 3ds Max beta.
Royal Ghost | veda3d.com
Steps to Reproduce:
Tags (2)
Labels (2)
10 REPLIES 10
Message 2 of 11
Stephen.Blair
in reply to: RGhost77
Stephen.Blair
I tested the release version MAXtoA 4.2.2.20 and the denoiser works.
Is there an error in the log? Or is there no error and the log shows that the denoiser works, but there's something wrong the output exr?
The beta is for reporting issues with the beta build. I did not test the beta builds.
// Stephen Blair
// Arnold Renderer Support
// Stephen Blair
Message 3 of 11
Stephen.Blair
Stephen.Blair
Ok, I'm guessing you mean the output of noice = the input ?
Testing now...
// Stephen Blair
Testing now...
// Stephen Blair
Message 4 of 11
RGhost77
RGhost77
Log shows no error, but final image doesn't have denoised result.
-- denoiser log: ---
Denoising G:/temp/!vray2arno/aa_Noice_Input.exr to G:/temp/!vray2arno/aa_denoise.exr
"c:\programdata\autodesk\applicationplugins\maxtoa_2022\noice.exe" -i "G:/temp/!vray2arno/aa_Noice_Input.exr" -o "G:/temp/!vray2arno/aa_denoise.exr" -v 0.5 -sr 9 -pr 3
noice 6.2.0.0.beta25 [a11d841a] - the Arnold denoiser
Using 16 threads.
Loading images...
Loading file "G:/temp/!vray2arno/aa_Noice_Input.exr".
Using feature AOV 'denoise_albedo' with filter 'gaussian_filter'
Using feature AOV 'N' with filter 'gaussian_filter'
Using feature AOV 'Z' with filter 'gaussian_filter'
Working with 1 frame at 800x600
Will denoise AOV "RGBA", using associated variance
Output file will be "G:/temp/!vray2arno/aa_denoise.exr"
Start denoising (patch radius 3, search radius 9, variance 0.5)
Denoising RGBA
Finished denoising
Saving image G:/temp/!vray2arno/aa_denoise.exr (800 x 600 x 4)
Denoising complete.
Also I attach images (input and output). https://www.dropbox.com/s/413sc9ypurzsrqc/aa.zip?dl=0
P.S. MAXtoA 4.3 beta has the same problem.
Using 16 threads.
Loading images...
Denoising RGBA
Finished denoising
Denoising complete.
Message 5 of 11
Stephen.Blair
Stephen.Blair
Using a scene from our test suite, I get a denoised result.
Using other quick test scenes, there was a difference, but the denoising wasn't obvious to my eye, I had to do a diff
I didn't have a chance to look at your files yet (it's still early here in Montreal)
// Stephen Blair
// Stephen Blair
Message 6 of 11
Stephen.Blair
Stephen.Blair
noice works, but there's only so much it can do with that [not-so-noisy] image.
Here's the diff in Nuke, where I had to bump up the gain and gamma to really see it:
Even with -v 0.000001 -pr 6 -sr 21 there's not much of a difference between the original and the denoised.
// Stephen Blair
// Stephen Blair
Message 7 of 11
RGhost77
RGhost77
I see, but it seems strange that denoised image looks much more the same as noise. I checked Arnold documentation and doesn't find any big changes in noice denoiser in last versions.
I ported back to old version of 3ds Max this scene and rendered test with 3.2.66 MAXtoA and achieved good denoise result.
Take a look (old version doesn't have Imagers so image exposure corrected in Photoshop):
Right side - input, left side denoised with default values.
Here the .exr files from 3.2.66 :https://www.dropbox.com/s/el230mg34t656qa/aa3.2.66.zip?dl=0
Message 8 of 11
RGhost77
RGhost77
Problem in Imagers. If disable it, noice works as expected. I think Imagers dramatically change RGB image so stored variance data is not valid for it.
So the question, Imagers would be supported by denoisers or not?
Message 9 of 11
Stephen.Blair
Stephen.Blair
@Mike Samoylov What imagers do you have in the scene?
// Stephen Blair
// Stephen Blair
Message 10 of 11
RGhost77
in reply to: Stephen.Blair
RGhost77
Exposure and Tonemap
Message 11 of 11
pproestos
pproestos
I didn't saw this thread, and I have post again the issue
that as I understand noice.exe don't work with imagers.
That's sad. What are we going to do now?
Back to active shade?
