Hi there,
Per the image below I feel I have all the settings correct when using a standard Volume for rending foam in max, but it is always black.
I have underlined the various elements I understand I need for this to work, yet it is always black.
Does anything jump out as obvious as to what I am doing incorrect.
Solved by Stephen.Blair. Go to Solution.
It's a problem with the bifrost_points object, and we have an open ticket for it.
You'll need to add an operator to set the step size. In this screenshot, I have a Set Parameter that sets the step_size (and I made the Set Parameter the target operator).
I would be surprised if the multi/sub-object worked with it tbh.
What happens when you just assign the standard_volume?
You have to set a target operator
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Operators
oh man this is hurting my head trying to get this sorted. Thanks, I'll see if I can put this together.
