Hi. After the recent maintenance/"rework" of the Area, it's not possible to stay logged in. After a (short) while you're automatically logged out, with a message saying "your session expired". This means that I have to log on 15 -20 times a day, if I want to use the Area like Ive done for years.
Is this a "bug" or is it intended behavior?
Solved by Discussion_Admin. Go to Solution.
We have always had a 30 min inactivity time out is this what you are takling about?
As for keep me signed in it is acting a little diffrently than before I'll get someone to lookinto it
Mark
Hi. Just to clearify. Until recent maintenance I have always had both my PC and my iPad logged in on the Area, via the "Keep me signed in" checkbox. Only on rare occasions I had to log in again. But now I have to constantly sign in. I don't know how your 30 inactivity time out works, but it seems like the limit is 30 sec?
Another thing: If I log in on the Areas front side, I'm automatically logged out when I go the Forum. Is this intended?
If you want to avoid people from helping each other during working hour, then you're certainly on the right path, but otherwise this needs to be changed.
no sso should keep you logged on in my mind can you post a screencast for me?
By the way it's a 30 min inactivity log off in the Lithium boards i corrected my earlier post.
Also please note it will most likely be tomorrow untill i can get it look at no one working but me
Mark
Hi. Not sure exactly what you wanted me to post, but I've attached 2 screendumps:
1) After I logged IN at Areas front side 10:48
2) After going to the forum, where I'm automatically logged OUT 10:49
As you can see everything is happening in the same minute, so it got nothing to do with the 30 min limit.
Hope it helps
please recheck the keep me signed in and inform me of any issues you are still seeing
Also if you are still having issues try deleting you cookies.
Mark
Hi. Well tried your suggestions (incl. deleting all cookies) without any changes. In fact I had to sign in 2 times within the same minute to poste this.
Now I need to "rebuild" my settings and sign in again to other forums as a result of deleting all 😞
Hope you'll sort this out soon - otherwise it'll be "Goodbye Area" for me.
What browser are you using? so I can try and duplicate.
Discussion_Admin
I'm using Safari (iPad) and Chrome (PC). None of them works as before your "rework" - even after following your advise. Also, in both of them a "log in" on the Areas front-page will automatically be dismissed when entering the Forums.
Sorry you are still having issues.
a couple of points of interest most browsers do allow for individual cookie deletions Autodesk and Lithium cookies would have work sorry for the miss communication. Second we did no work on the keep me signed in nothing was changed.
A couple of things were inadvertently turned off when the community came back up but they have since been turned back on so in theory a cookie reset should have fixed the issue
Please check the following setting in Google Chrome, Settings > Content Settings > Cookies > Make sure it is set to allow local data to be set
Also do you have issues with keep me signed in when you go straight to the community links and skip the AREA log on?
A screencast of what you are seeing would really help out and its free to download and use
Mark
Hi. Checked my browser settings, and they are all as they should be. Also tried to clean up a bit in my account settings, to see if that helped, but no changes. I did find one more odd thing however:
If I go to the Area site, and press "Log In" (top right, front page), then I'm automatically recognized and logged on, but as allready mentioned I'm being locked out as soon as I go to the forum. The new thing I discovered is, that if I go to my account page ("About PROH", then I'm automtically logged on, and I choose one of my "recent" links I'll stay locked on when entering the forum. This is happening on both iPad and PC.
As for now I'm using this workaround whenever I'm locked out (session expired), but I find it very odd that you claimes that nothing has changed - despite the fact that other users than me also find the whole Area page wacky and unstable.
I really hope you find a solution soon.
BTW - I can't see what a screen-cast would tell you that I didn't already show in the attached pictures or tell you in my description. Besides that, I don't think a screencast of me loggin on is in anyway a good (nor healthy) idea.
I have a theory based on your last post and we really did not change anything.
Can you add the URLs to the other posts in area that have users complaints of this type or just use the RIC button with keep me login as a note
Discussion_Admin
PS. I was looking for work flow information with the screencast request( they can be made private url viewing only for security) but it is not needed now
Here's one: http://forums.autodesk.com/t5/3ds-max-3ds-max-design-general/what-happened-to-the-quot-area-quot/td-...
We are supposed to have fix in place now can you please check your normal work flow to confirm?
Discussion_Admin
Hi. That sounds great. I'll test it ASAP (probably not before Tuesday), but I have already noticed a change (for the better) on my iPad.
I'll report back.
Hi. I wrote Tuesday but meant Thursday.... Anyway, it seems like the fix solved the problem - both on iPad and PC 🙂
Thank you.
