assert(theta >0.0001 and theta < (2.0*math.pi)) assert(normal.length ==1) assert(axis.length ==1) r1 = adsk.core.Matrix3D.create() r2 = adsk.core.Matrix3D.create() r1.setToRotation(theta/2.0, normal, origin) ui.messageBox("r1:"+str(r1.asArray())) r2.setToRotation(math.pi*2.0 - theta/2.0, normal, origin) c1 = axis assert(c1.transformBy(r1)) assert(c1.length >0.0001 or c1.length<-0.0001) assert(c1.isPerpendicularTo(normal))
I'm trying to rotate a vector by a user specified angle about a normal to a given plane. Using the rotation matrix functions available.
However this seems to fail because c1 results in the same vector at axis. I'm testing with theta == math.radians(45), a normal of (0,1,0) (y axis) and an axis of (-1,0,0) (reverse x axis)
I would expect the Vector3D.transformBy(Matrix3D) function to compute M*v in and then set v based on homogenized coordinates. Is this not true
Is there an alternative way to compute a vector rotated about an arbitrary axis.
I had a hard time following what you were trying to do in the sample code. Here's a simple example that creates a vector in the X direction and then uses a matrix to rotate it 90 degrees around the Z axis and it returns the correct result.
def vectorTransform(): ui = None try: app = adsk.core.Application.get() ui = app.userInterface vec = adsk.core.Vector3D.create(1,0,0) mat = adsk.core.Matrix3D.create() mat.setToRotation(math.pi/2, adsk.core.Vector3D.create(0,0,1), adsk.core.Point3D.create(0,0,0)) ui.messageBox(str(vec.asArray())) vec.transformBy(mat) ui.messageBox(str(vec.asArray())) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It seems the transformBy function does not apply the translational part of the matrix when using Vector3D instead of Point3D, checkout the following simple example:
import adsk.core def run(context): m = adsk.core.Matrix3D.create() m.translation = adsk.core.Vector3D.create(0,0,1) print(m.asArray()) # (1.0, 0.0, 0.0, 0.0, # 0.0, 1.0, 0.0, 0.0, # 0.0, 0.0, 1.0, 1.0, # 0.0, 0.0, 0.0, 1.0) v = adsk.core.Vector3D.create(0,0,0) v.transformBy(m) print(v.asArray()) # (0.0, 0.0, 0.0) v = adsk.core.Point3D.create(0,0,0) v.transformBy(m) print(v.asArray()) # (0.0, 0.0, 1.0)
Looks like a serious bug to me...
The Matrix implementation exposed by Fusion is fully functional and correct - just very non standard IMO - speaking as someone who is used to graphical Matrix operations such as HTML's canvas or GDI/GDI+
I've written a wrapper over the Matrix class which makes it behave how I expect/need. Feel free to use it as a base for your own or as-is. This code contains a few other choice helpers as well. I call this file "better_types.py" 😉
__all__ = ['Point3D', 'format_point', 'points_eq', 'Matrix', 'ObjectCollectionFromList', 'ObjectCollectionToList', 'ConcatenateObjectCollections'] import adsk.core, adsk.fusion from numbers import Number def format_point(point, fmt='{:}'): s = '(' s += fmt.format(point.x) s += ', ' s += fmt.format(point.y) if point.z: s += ', ' + fmt.format(point.z) s += ')' return s def points_eq(p1, p2, epsilon=1e-8): if p1 is p2: return True if isinstance(p1, adsk.fusion.SketchPoint): p1 = p1.geometry if isinstance(p2, adsk.fusion.SketchPoint): p2 = p2.geometry dx = (p1.x - p2.x)**2 dy = (p1.y - p2.y)**2 dz = (p1.z - p2.z)**2 return (dx + dy + dz) <= epsilon**2 def Point3D(x, y, z=0): return adsk.core.Point3D.create(x, y, z) def ObjectCollectionFromList(l): oc = adsk.core.ObjectCollection.create() for item in l: oc.add(item) return oc def ObjectCollectionToList(oc): l = [] for item in oc: l.append(item) return l def ConcatenateObjectCollections(l, r): for item in r: l.add(item) return l class Matrix(object): X_AXIS = adsk.core.Vector3D.create(1, 0, 0) Y_AXIS = adsk.core.Vector3D.create(0, 1, 0) Z_AXIS = adsk.core.Vector3D.create(0, 0, 1) ORIGIN = adsk.core.Point3D.create(0, 0, 0) def __init__(self, from_matrix=None): if from_matrix is None: self._m = adsk.core.Matrix3D.create() elif isinstance(from_matrix, Matrix): self._m = from_matrix._m.copy() elif isinstance(from_matrix, adsk.core.Matrix3D): self._m = from_matrix.copy() else: raise 'Invalid transformation matrix type.' def as_fusion_matrix3D(self): return self._m.copy() def copy(self): return Matrix(self) def identity(self): self._m = adsk.core.Matrix3D.create() return self def translate(self, x_or_point, y=0, z=0): if isinstance(x_or_point, Number): x = x_or_point else: x = x_or_point.x y = x_or_point.y z = x_or_point.z m = adsk.core.Matrix3D.create() m.translation = adsk.core.Vector3D.create(x, y, z) self._m.transformBy(m) return self def rotate_about_x_axis(self, angle): """Rotates about the x-axis.""" m = adsk.core.Matrix3D.create() m.setToRotation(angle, Matrix.X_AXIS, Matrix.ORIGIN) self._m.transformBy(m) return self def rotate_about_y_axis(self, angle): """Rotates about the y-axis.""" m = adsk.core.Matrix3D.create() m.setToRotation(angle, Matrix.Y_AXIS, Matrix.ORIGIN) self._m.transformBy(m) return self def rotate_about_z_axis(self, angle): """Rotates about the z-axis.""" m = adsk.core.Matrix3D.create() m.setToRotation(angle, Matrix.Z_AXIS, Matrix.ORIGIN) self._m.transformBy(m) return self def scale(self, x=1, y=1, z=1): a = [x, 0, 0, 0, 0, y, 0, 0, 0, 0, z, 0, 0, 0, 0, 1] m = adsk.core.Matrix3D.create() m.setWithArray(a) self.multiply(m) return self def reflect_about_yz(self): """Reflects through the X axis about the YZ plane.""" return self.scale(-1, 1, 1) def reflect_about_xz(self): """Reflects through the Y axis about the XZ plane.""" return self.scale(1, -1, 1) def reflect_about_xy(self): """Reflects through the Z axis about the XY plane.""" return self.scale(1, 1, -1) def multiply(self, other): self._m.transformBy(other) return self def purify(self): a = self._m.asArray(); b = [] for i in range(16): if abs(a[i]) < 1e-15: b.append(0) elif abs(abs(a[i]) - 1) < 1e-15: if a[i] < 0: b.append(-1) else: b.append(1) else: b.append(a[i]) self._m.setWithArray(b) return self def transform(self, x_or_points, y=0, z=0): """Transforms a list of points, a single point, or a literal x,y,z and returns a new list of, or single, transformed point(s). Args: x_or_points: May be a list of points, a single point, or a number representing 'x'. y: y cord z: z cord """ if isinstance(x_or_points, list): new_points = [] for p in x_or_points: b = p.copy() b.transformBy(self._m) new_points.append(b) return new_points if isinstance(x_or_points, Number): b = Point3D(x_or_points, y, z) else: assert isinstance(x_or_points, adsk.core.Point3D) or isinstance(x_or_points, adsk.core.Vector3D) b = x_or_points.copy() b.transformBy(self._m) return b
