In my plugin analyse the interference of bodies to inform the user if there model is likely to work (ie, a bolt isn't intersecting some geometry).
To do this I need to quickly check interference across the design, which can be computationally expensive. From what I can see the quickest way to guess at this it test bounding boxes (way faster than complex bodies but obviously not accurate). After that I wonder what is faster.
The API supports analysing interference (link below), and alternatively I could use basic combine features like cut and intersect to get similar results. In the end I want to do the latter since I want the user to be able to visualize the flaws and analysing interference doesn't output anything to see.
Is analysing interference significantly faster that using combineFeatures? If its significantly faster (ie order of magnitude) it could be worth checking the design like that and narrowing what needs to go through combine process. Unfortunately the API never says how fast I could expect anything to be. Does anyone know, or have a guess at the efficiency differences between these two methods?
Inteference Reference:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-613cb65c-61c3-11e5-9a1c-3417ebd3d5be
Solved by ekinsb. Go to Solution.
Using the analyzeInterference method and the capabilities already there is going to be much faster than trying to write this on your own; both from a standpoint of writing the code and in the execution of the program. You can get information about the interference geometry. The analyzeInterference returns transient BRepBody objects that you can query to get more information about the interferences and, as the program below demonstrates, you can also use these to create real bodies in the model. However, creating bodies directly without building features is only supported in direct modeling documents or a base feature in a parametric document. Creating bodies in a base feature is demonstrated below.
import adsk.core, adsk.fusion, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface design = adsk.fusion.Design.cast(app.activeProduct) # Get the root component of the active design rootComp = design.rootComponent # Create a collection of the bodies to check for interference inputBodies = adsk.core.ObjectCollection.create() for body in rootComp.bRepBodies: inputBodies.add(body) # Create the interferenceInput object and run the analysis. interferenceInput = design.createInterferenceInput(inputBodies) interferenceInput.areCoincidentFacesIncluded = False results = design.analyzeInterference(interferenceInput) # Check to see if there were any interferences found. if results.count == 0: ui.messageBox('No interference found.') else: # Create a base feature containing the interference bodies. baseFeat = rootComp.features.baseFeatures.add() baseFeat.name = 'Inteference Results' baseFeat.startEdit() intResult = adsk.fusion.InterferenceResult.cast(None) for intResult in results: body = rootComp.bRepBodies.add(intResult.interferenceBody, baseFeat) body.name = 'Interference ' + body.name baseFeat.finishEdit() ui.messageBox(str(results.count) + ' interferences found.') except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
