Is there a way suppress the warning about a recovery file when opening a file from the javascript API? This isn't a big problem since it only Fusion doesn't crash very often when my script is running normally. However when Fusion does crash, the whole application grinds to a halt...
Solved by ekinsb. Go to Solution.
There isn't a way to suppress this that I'm aware of. I think the best behavior would be that it never displays when you open a document using the API. I'll log a defect for this.
Good news! This is getting fixed in our upcoming May update!
