Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Skip "A backup recovery file exists..." prompt when opening document
3 REPLIES 3
276 Views, 3 Replies
Is there a way suppress the warning about a recovery file when opening a file from the javascript API? This isn't a big problem since it only Fusion doesn't crash very often when my script is running normally. However when Fusion does crash, the whole application grinds to a halt...
3 REPLIES 3
ekinsb
There isn't a way to suppress this that I'm aware of.  I think the best behavior would be that it never displays when you open a document using the API.  I'll log a defect for this.
Brian Ekins
Mod the Machine blog
in reply to: ekinsb
Thanks Brian!
keqingsong
Good news! This is getting fixed in our upcoming May update!
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Autodesk DevCon in Munich May 28-29th
