Sketches on multiple offset construction planes
Hi all-
Fairly new to Fusion 360 and definitely to this API/programming...
I want to basically have an external file of coordinates being imported (something like the importCSV script) and have curves drawn on sketches that are on a series of offset construction planes (see below) - we'll deal with looping later... I've been cobbling together two of the sample API scripts to get a better grasp of how to do this and have ended up with this so far:
So, how do I 1. create a sketch on a construction plane and 2. create a curve on that new sketch? Thanks!
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# Create a document.
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
# Get the root component of the active design
rootComp = design.rootComponent
# Create sketch
sketches = rootComp.sketches
sketch = sketches.add(rootComp.xZConstructionPlane)
# Create sketch circle
sketchCircles = sketch.sketchCurves.sketchCircles
centerPoint = adsk.core.Point3D.create(0, 0, 0)
sketchCircles.addByCenterRadius(centerPoint, 5.0)
# Get the profile defined by the circle
prof = sketch.profiles.item(0)
# Get construction planes
planes = rootComp.constructionPlanes
# Create construction plane input
planeInput = planes.createInput()
# Add construction plane by offset
offsetValue = adsk.core.ValueInput.createByReal(3.0)
planeInput.setByOffset(prof, offsetValue)
planeOne = planes.add(planeInput)
# Create an object collection for the points.
points = adsk.core.ObjectCollection.create()
# Define the points the spline with fit through.
points.add(adsk.core.Point3D.create(0, 0, 0))
points.add(adsk.core.Point3D.create(5, 1, 0))
points.add(adsk.core.Point3D.create(6, 4, 0))
# Create the spline.
sketch.sketchCurves.sketchFittedSplines.add(points)
offsetValue = adsk.core.ValueInput.createByReal(6.0)
planeTwo = planes.add(planeInput)
points.add(adsk.core.Point3D.create(3, 7, 0))
points.add(adsk.core.Point3D.create(5, 9, 0))
offsetValue = adsk.core.ValueInput.createByReal(9.0)
planeThree = planes.add(planeInput)
points.add(adsk.core.Point3D.create(2, 5, 0))
points.add(adsk.core.Point3D.create(3, 8, 0))
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
ekinsb
Here's a modified version of your program that creates a series of curves on different construction planes and then creates a loft feature through them.  The thing to always start with when you're automating some process like this is to go through the same steps in the user interface and pay careful attention to the steps needed. In your code you were getting the profile from the sketch and using that to create then construction plane.  Profiles represent the closed areas within a sketch that are drawn as filled in.  When drawing a single open curve, there aren't any profiles.  I modified the program to build the construction planes using one of the base construction planes. For open curves you can create a "Path" rather than a profile.  I do that with each curve that's drawn and then finally use those paths to create a loft feature.
def run(context):
    ui = None
    try:
        # Create sketch
        sketchArcs = sketch.sketchCurves.sketchArcs
        arc = sketchArcs.addByThreePoints(adsk.core.Point3D.create(0,0,0),
                                          adsk.core.Point3D.create(3,2,0),
                                          adsk.core.Point3D.create(6,0,0))
        # Create a path using the arc.
        paths = []
        paths.append(adsk.fusion.Path.create(arc, adsk.fusion.ChainedCurveOptions.noChainedCurves))
        planeInput.setByOffset(rootComp.xZConstructionPlane, offsetValue)
        constPlane = planes.add(planeInput)
        sketch = sketches.add(constPlane)
        curve = sketch.sketchCurves.sketchFittedSplines.add(points)
        paths.append(adsk.fusion.Path.create(curve, adsk.fusion.ChainedCurveOptions.noChainedCurves))
        loftInput = rootComp.features.loftFeatures.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        for path in paths:
            loftInput.loftSections.add(path)
        rootComp.features.loftFeatures.add(loftInput)
    except:
        if ui:
Brian Ekins
Mod the Machine blog
Thank you much for the code and explanation - this makes more sense.
Additionally, funny you added the loft - I was going to ask a follow up question about doing something similar using tsplines - the question being, how would I go about creating coordinate control points - but what you did does just that!
