I created a triangle of sketchLines with one vertex at the origin of the sketch. I then created a line that intersects (and extends past) both sides that share the origin at the vertex. I can use trim on the intersecting line and give it the Point3D of either end of the intersecting line and it functions fine. However, when I try to use trim on either sketchLine that contains the origin and give it the Point3D of the origin, it does not trim the lines. I have give it some point between the origin and the intersecting line to work. Not sure if this is a bug or just a result of the algorithm that finds the distance to the trim side.
Solved by ekinsb. Go to Solution.
Hi Dirk,
I'm not sure I fully understand what you're trying to do? Can you post of screenshot of the geometry and what you're trying to trim? Can you perform the desired trim interactively in Fusion?
Here's the code that fails to trim unless you move the trim point off zero,zero in the +x direction
If you uncomment the "trimPoint.x += iD/2" line, it will work as expected
#Author Dirk Van Essendelft #Copyright 12/25/2014 21st Century Woodworking import adsk.core, adsk.fusion, traceback, math, time class SegRing: def __init__(self): try: self.app = adsk.core.Application.get() self.core = adsk.core self.ui = self.app.userInterface self.product = self.app.activeProduct self.design = adsk.fusion.Design.cast(self.product) self.rootComp = self.design.rootComponent self.sketches = self.rootComp.sketches self.pi = 3.1415926535897932384626433832795028841971693993751058209749445923078164062 self.globalOrigin = adsk.core.Point3D.create(0,0,0) self.extrudes = self.rootComp.features.extrudeFeatures except: if self.ui: self.ui.messageBox('Problem in __init__:\n{}'.format(traceback.format_exc())) def createSegmentComp(self,n,iD,oD,height): newOcc = self.rootComp.occurrences.addNewComponent(adsk.core.Matrix3D.create()) comp = newOcc.component comp._set_name('Single_Segment') sketches = comp.sketches sketch = sketches.add(comp.xZConstructionPlane) sketch._set_isVisible(False) sketch._set_name('SegmentOutline') sketchLines = sketch.sketchCurves.sketchLines sketchPoints = sketch.sketchPoints angle = 2.0*self.pi/n halfAngle = angle/2.0 drawingOrigin = self.globalOrigin.copy() sketchPointOrigin = sketchPoints.add(drawingOrigin) sketchPointOrigin._set_isFixed(True) #Create Lower Line lowerLineStart = drawingOrigin.copy() lowerLineEnd = drawingOrigin.copy() lowerLineEnd.x = lowerLineEnd.x + math.cos(halfAngle) * oD * 2 lowerLineEnd.y = lowerLineEnd.y - math.sin(halfAngle) * oD * 2 lowerLine = sketchLines.addByTwoPoints(lowerLineStart,lowerLineEnd) #Create Upper Line upperLineStart = drawingOrigin.copy() upperLineEnd = drawingOrigin.copy() upperLineEnd.x = upperLineEnd.x + math.cos(halfAngle) * oD * 2 upperLineEnd.y = upperLineEnd.y + math.sin(halfAngle) * oD * 2 upperLine = sketchLines.addByTwoPoints(upperLineStart,upperLineEnd) #Create Outter Line oDLineStart = drawingOrigin.copy() oDLineStart.x += oD oDLineStart.y += oD oDLineEnd = oDLineStart.copy() oDLineEnd.y -= 2 * oD odLine = sketchLines.addByTwoPoints(oDLineStart,oDLineEnd) #Create Inner Line idLineStart = drawingOrigin.copy() idLineEnd = drawingOrigin.copy() idLineStart.x = math.cos(halfAngle) * iD idLineStart.y = -1.0 * oD idLineEnd.x = idLineStart.x idLineEnd.y = -1.0 * idLineStart.y idLine = sketchLines.addByTwoPoints(idLineStart,idLineEnd) #Trim Lines to Create Trapizoid lowerLine.trim(lowerLineEnd) upperLine.trim(upperLineEnd) odLine.trim(oDLineStart) odLine.trim(oDLineEnd) idLine.trim(idLineStart) idLine.trim(idLineEnd) # lineReturn = lowerLine.breakCurve(idLine.startSketchPoint.geometry,True) # print(lineReturn.count) trimPoint = upperLine.startSketchPoint.geometry.copy() # trimPoint.x += iD/2 lowerLine.trim(trimPoint) upperLine.trim(trimPoint) def main(): try: nSeg = 8 # Number of Segments inerDia = 3 # inner diameter outterDia = 4 # outter diameter ringHeight = 1 # height of ring sR = SegRing() sR.createSegmentComp(nSeg,inerDia,outterDia,ringHeight) except: sR.ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) main()
BTW, the code still failed if I moved off the zero, zero position to the negative x direction. According to the docs, I should be able to feed it a Poind3D object the is closest to the side of the trim and have it function correctly. In this example, any -x position should be closer than any point that is betweeen 0 and cos(iD) so it should trim the line, but it doesnt.
I think I stated that incorrectly. any -x position should be closer to the side of the trim line than any point with an x value grater than cos(iD). Basically I would expect it to trim correctly with any point with an x less than cos(iD) wich would include 0,0 or anything y,<0 but it doesn't.
Using your code as-is it creates the triangle with the mid-line but fails to trim the top and bottom lines. However, if I uncomment the line:
trimPoint.x += iD/2
I get the expected results. This makes sense to me because specifying the trim point at the origin is ambiguous. When trimming the bottom line and specifying the origin as the trim point it could assume you want to trim to the top line, which results in no change. Moving the point in the positive direction, anywhere along the red area I've highlighted below should perorm the trim as expected and that's the result I'm seeing.
Here's what I get after uncommenting the line to modify the X coordinate of the trim point.
I kind of disagree. There should be no ambiguity becasue I am calling the trim method within the sketchLine instance. To me that means the trim method is only going to ack on that specific sketchLine instance. How is that ambiguous as to which sketchLine is going to get trimmed? Thats why there are two calls to trim for each sketchLine instance, one for lowerLine and one for upperLine. How can a method in one instance act on another?
I wasn't clear in my last post. Which line to trim isn't ambiguous, but where to trim the line is. The trim operation finds all entities that intersect the entity you want to trim and then you specify the section between intersections to be trimmed by specifying a point in the area to trim. What's ambiguous is if this point is the same as one of the intersection points. Fusion doesn't know which side of the point to remove. In your case the origin is the same point as the intersection of the bottom and top lines.
That makes sense to me. I understand now. Thats why a negative x value wouldn't work eigher because there would be nothing to trim on that side of the intersection point at the origin. I get it now. Wish I could read the code for the operations. It would make life a bit easier.
