Rhino software has Grasshopper for parametric modeling, is there anything like that for fusion 360 ?
Solved by dirktheeng. Go to Solution.
Fusion 360 is a parametric modeler. You don't need any plugins to do parametric modeling. If you want to script it you can as well with the API
You can do this in Fusion 360 without programming. It's a fairly complex model but you could do it. You can use a cobination of swept bodies and scultpted bodies (TSplines) to do it. Look on the gallery for a guy who made a skull and a vace that were ribbon like. he has a couple video's to show how to do this kind of thing.
Found him, definitely helpful ! https://fusion360.autodesk.com/projects/shreded-skulls
