Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Parametric modeling ?
5 REPLIES 5
KirillChepizhko
1316 Views, 5 Replies
Rhino software has Grasshopper for parametric modeling, is there anything like that for fusion 360 ?
Tags (1)
5 REPLIES 5
Fusion 360 is a parametric modeler.  You don't need any plugins to do parametric modeling.  If you want to script it you can as well with the API
21st Century Woodworking
-Blending 21st Century Woodworking with Old World Skill
Unfortunately I dont know any programming, so I was hoping that there is
some visual solution for it. What would be the right approach to achieve
smth like the example in the attachment ?
You can do this in Fusion 360 without programming.  It's a fairly complex model but you could do it.  You can use a cobination of swept bodies and scultpted bodies (TSplines) to do it.  Look on the gallery for a guy who made a skull and a vace that were ribbon like.  he has a couple video's to show how to do this kind of thing.
Will give it a shot , thank you
Sent from my T-Mobile 4G LTE Device
