Palette Sample not working?
I'm not sure what I've done wrong, but I can't seem to get the palette sample to work. I've made an add in from the code here:http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-c97b8ed2-e1da-11e6-af4c-3417ebc87622
I didn't make any changes, but when I try to use the 'send info to Palette' button I get the error pictured. When I click the 'click to send info to Fusion' button on the palette nothing happens. What could cause this if I didn't edit the sample code?
ekinsb
Thank you for reporting this.  I can reproduce it and have found the problems.  The good news is that the problem isn't with Fusion but was with the sample code.  I made a couple of last minute changes as I was publishing it and apparently I broke it.  I've fixed it in the help system so it will be available with the next Fusion update.  Until then here's the updated html and py source.
palette.html
<!DOCTYPE html>
<html>
    <head>
    </head>
    <body>
        <p id='p1'>Click the button below or use the "Send info to HTML" command in the ADD-INS panel.</p>
        <button type='button' onclick='sendInfoToFusion()'>Click to send info to Fusion</button>
        <br /><br />
    </body>
    <script>
        function sendInfoToFusion(){
            var args = {
                arg1 : "Sample argument 1",
                arg2 : "Sample argument 2"
            adsk.fusionSendData('send', JSON.stringify(args));
        window.fusionJavaScriptHandler = {handle: function(action, data){
            try {
                if (action == 'send') {
					// Update a paragraph with the data passed in.
					document.getElementById('p1').innerHTML = data;
				else if (action == 'debugger') {
                    debugger;
				else {
					return 'Unexpected command type: ' + action;
            } catch (e) {
                console.log(e);
                console.log('exception caught with command: ' + action + ', data: ' + data);
            return 'OK';
    </script>
</html>
Python Source
import adsk.core, adsk.fusion, adsk.cam, traceback
import json
# global set of event handlers to keep them referenced for the duration of the command
handlers = []
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
num = 0
# Event handler for the commandExecuted event.
class ShowPaletteCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            # Create and display the palette.
            palette = _ui.palettes.itemById('myPalette')
            if not palette:
                palette = _ui.palettes.add('myPalette', 'My Palette', 'palette.html', True, True, True, 300, 200)
                # Dock the palette to the right side of Fusion window.
                palette.dockingState = adsk.core.PaletteDockingStates.PaletteDockStateRight
                # Add handler to HTMLEvent of the palette.
                onHTMLEvent = MyHTMLEventHandler()
                palette.incomingFromHTML.add(onHTMLEvent)
                handlers.append(onHTMLEvent)
                # Add handler to CloseEvent of the palette.
                onClosed = MyCloseEventHandler()
                palette.closed.add(onClosed)
                handlers.append(onClosed)
            else:
                palette.isVisible = True
        except:
            _ui.messageBox('Command executed failed: {}'.format(traceback.format_exc()))
# Event handler for the commandCreated event.
class ShowPaletteCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            command = args.command
            onExecute = ShowPaletteCommandExecuteHandler()
            command.execute.add(onExecute)
            handlers.append(onExecute)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class SendInfoCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            # Send information to the palette. This will trigger an event in the javascript
            # within the html so that it can be handled.
            if palette:
                global num
                num += 1
                palette.sendInfoToHTML('send', 'This is a message sent to the palette from Fusion. It has been sent {} times.'.format(num))
        except:
class SendInfoCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            onExecute = SendInfoCommandExecuteHandler()
        except:
# Event handler for the palette close event.
class MyCloseEventHandler(adsk.core.UserInterfaceGeneralEventHandler):
    def __init__(self):
        super().__init__()
        try:
            _ui.messageBox('Close button is clicked.')
        except:
# Event handler for the palette HTML event.
class MyHTMLEventHandler(adsk.core.HTMLEventHandler):
    def __init__(self):
        super().__init__()
        try:
            htmlArgs = adsk.core.HTMLEventArgs.cast(args)
            data = json.loads(htmlArgs.data)
            msg = "An event has been fired from the html to Fusion with the following data:\n"
            msg += '    Command: {}\n    arg1: {}\n    arg2: {}'.format(htmlArgs.action, data['arg1'], data['arg2'])
            _ui.messageBox(msg)
        except:
def run(context):
    try:
        global _ui, _app
        _app = adsk.core.Application.get()
        _ui  = _app.userInterface
        # Add a command that displays the panel.
        showPaletteCmdDef = _ui.commandDefinitions.itemById('showPalette')
        if not showPaletteCmdDef:
            showPaletteCmdDef = _ui.commandDefinitions.addButtonDefinition('showPalette', 'Show custom palette', 'Show the custom palette', '')
            # Connect to Command Created event.
            onCommandCreated = ShowPaletteCommandCreatedHandler()
            showPaletteCmdDef.commandCreated.add(onCommandCreated)
            handlers.append(onCommandCreated)
        # Add a command under ADD-INS panel which sends information from Fusion to the palette's HTML.
        sendInfoCmdDef = _ui.commandDefinitions.itemById('sendInfoToHTML')
        if not sendInfoCmdDef:
            sendInfoCmdDef = _ui.commandDefinitions.addButtonDefinition('sendInfoToHTML', 'Send info to Palette', 'Send Info to Palette HTML', '')
            onCommandCreated = SendInfoCommandCreatedHandler()
            sendInfoCmdDef.commandCreated.add(onCommandCreated)
        # Add the command to the toolbar.
        panel = _ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl = panel.controls.itemById('showPalette')
        if not cntrl:
            panel.controls.addCommand(showPaletteCmdDef)
        cntrl = panel.controls.itemById('sendInfoToHTML')
        if not cntrl:
            panel.controls.addCommand(sendInfoCmdDef)
    except:
        if _ui:
def stop(context):
    try:
        # Delete the palette created by this add-in.
        if palette:
            palette.deleteMe()
        # Delete controls and associated command definitions created by this add-ins
        cmd = panel.controls.itemById('showPalette')
        if cmd:
            cmd.deleteMe()
        cmdDef = _ui.commandDefinitions.itemById('showPalette')
        if cmdDef:
            cmdDef.deleteMe()
        cmd = panel.controls.itemById('sendInfoToHTML')
        if cmd:
            cmd.deleteMe()
        cmdDef = _ui.commandDefinitions.itemById('sendInfoToHTML')
        if cmdDef:
            cmdDef.deleteMe()
        _ui.messageBox('Stop addin')
    except:
        if _ui:
Brian Ekins
Mod the Machine blog
I tried to run Palette Sample on my Windows PC, but it doesn't work as expected. Palette Dialog doesn't show up.
I have read related topics on this forum, but so far no success. The script show only small dialog with 'Stop addin' message.
Is the sample code from current (January, 17th, 2019) this
Programming Interface/Sample Programs/User Interface/General/Palette Sample web page updated and correct? Or should I use the code from the post above?
The .html file is in the same directory as the .py code. Anyhow I tried to trace the python code. I set a break point into the ShowPaletteCommandExecuteHandler.notify. It looks like the code doesn't even reach the method. (the handler is never called)
How is the correct string-path for the html file?  Relative path works? How to write absolute path?
Is for example this correct on Windows PC:   'D:\\GitHub\\Fusion360\\Scripts\\ApiSamplePalette\\palette.html'   ?
Thank you
