In the docs you have a link from the derrived from object. For example, the ExtrudeFeature object has a link to the Feature object that it is derrived from, but it would be useful for the Feature object to have dependant objects listed such as ExtrudeFeature, RevolveFeature, SweptFeature, etc so we can walk through the docs easy.
This could go for the objects listed in the tree to the left under Fusion 360 Reference Model. Maybe there should be 2 lists, one that is alphabetical (like the one now) and one that is hierarchical based on calss inheritance. this would make using the API so much easier and faster.
Solved by ekinsb. Go to Solution.
Thanks for this suggestion. I'm going to investigate adding a seperate section listing all of the classes that are derived from the current class. I think this will be relatively easy to do and would be useful.
