Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Orbit, zoom, pan fundamental viewport controls
2 REPLIES 2
pravdomil
563 Views, 2 Replies
Hello there I'm working on new input device to work with Fusion 360 via 3rd Addins.
And I'm searching for implementation of fundamental viewport controls (pan, zoom, orbit) in C++.
Does anybody have some idea how to do that? This is my code that does not work 😞
void orbit(Ptr& screenCoordinateCenter, double deltaX, double deltaY) {
    Ptr camera = app->activeViewport()->camera();
    camera->isSmoothTransition(false);
    Ptr eye = camera->eye();
    eye->x(eye->x() + deltaX);
    eye->y(eye->y() + deltaY);
    camera->eye(eye);
    app->activeViewport()->camera(camera);
    app->activeViewport()->refresh();
void pan(double deltaX, double deltaY) {
    camera->eye(eye);
    Ptr target = camera->target();
    target->x(target->x() + deltaX);
    target->y(target->y() + deltaY);
    camera->target(target);
2 REPLIES 2
JakobczakMarek
in reply to: pravdomil
try this: simple move based on your code, I thing this is not bad point to start.
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
#include <CAM/CAMAll.h>
using namespace adsk::core;
using namespace adsk::fusion;
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
void orbit(Ptr<Camera> screenCoordinateCenter, double deltaX, double deltaY)
    Ptr<Camera> cam = screenCoordinateCenter;
    cam->isSmoothTransition(false);
    Ptr<Point3D> eye = cam->eye();
    cam->eye(eye);
    app->activeViewport()->camera(cam);
    Ptr<Camera> cam = app->activeViewport()->camera();
    cam->eye(eye);
    Ptr<Point3D> target = cam->target();
    cam->target(target);
void delay(int val)
    for(int i = 0; i < val; ++i)
        for(int k = 0; k < val; ++k)
extern "C" XI_EXPORT bool run(const char* context)
	app = Application::get();
	if (!app)
		return false;
	ui = app->userInterface();
	if (!ui)
		return false;
    ui->messageBox("About to start...");
    Ptr<Camera> camera1 = app->activeViewport()->camera();
    double x = 0;
    double y = 0;
    for(int i = 0; i < 90; ++i)
        orbit(camera1, x, y);
//        delay(10);
        x += 1.0;
        y += 1.0;
	ui->messageBox("Done");
	return true;
Goodluck.
Marek
pravdomil
in reply to: JakobczakMarek
Well try pan function, when you rotate camera it no longer goes in the same direction.
