Hello there I'm working on new input device to work with Fusion 360 via 3rd Addins.
And I'm searching for implementation of fundamental viewport controls (pan, zoom, orbit) in C++.
Does anybody have some idea how to do that? This is my code that does not work 😞
void orbit(Ptr& screenCoordinateCenter, double deltaX, double deltaY) { Ptr camera = app->activeViewport()->camera(); camera->isSmoothTransition(false); Ptr eye = camera->eye(); eye->x(eye->x() + deltaX); eye->y(eye->y() + deltaY); camera->eye(eye); app->activeViewport()->camera(camera); app->activeViewport()->refresh(); } void pan(double deltaX, double deltaY) { Ptr camera = app->activeViewport()->camera(); camera->isSmoothTransition(false); Ptr eye = camera->eye(); eye->x(eye->x() + deltaX); eye->y(eye->y() + deltaY); camera->eye(eye); Ptr target = camera->target(); target->x(target->x() + deltaX); target->y(target->y() + deltaY); camera->target(target); app->activeViewport()->camera(camera); app->activeViewport()->refresh(); }
try this: simple move based on your code, I thing this is not bad point to start.
#include <Core/CoreAll.h> #include <Fusion/FusionAll.h> #include <CAM/CAMAll.h> using namespace adsk::core; using namespace adsk::fusion; using namespace adsk::cam; Ptr<Application> app; Ptr<UserInterface> ui; void orbit(Ptr<Camera> screenCoordinateCenter, double deltaX, double deltaY) { Ptr<Camera> cam = screenCoordinateCenter; cam->isSmoothTransition(false); Ptr<Point3D> eye = cam->eye(); eye->x(eye->x() + deltaX); eye->y(eye->y() + deltaY); cam->eye(eye); app->activeViewport()->camera(cam); app->activeViewport()->refresh(); } void pan(double deltaX, double deltaY) { Ptr<Camera> cam = app->activeViewport()->camera(); cam->isSmoothTransition(false); Ptr<Point3D> eye = cam->eye(); eye->x(eye->x() + deltaX); eye->y(eye->y() + deltaY); cam->eye(eye); Ptr<Point3D> target = cam->target(); target->x(target->x() + deltaX); target->y(target->y() + deltaY); cam->target(target); app->activeViewport()->camera(cam); app->activeViewport()->refresh(); } void delay(int val) { for(int i = 0; i < val; ++i) { for(int k = 0; k < val; ++k) { ; } } } extern "C" XI_EXPORT bool run(const char* context) { app = Application::get(); if (!app) return false; ui = app->userInterface(); if (!ui) return false; ui->messageBox("About to start..."); Ptr<Camera> camera1 = app->activeViewport()->camera(); double x = 0; double y = 0; for(int i = 0; i < 90; ++i) { orbit(camera1, x, y); // delay(10); x += 1.0; y += 1.0; } ui->messageBox("Done"); return true; }
Goodluck.
Marek
Well try pan function, when you rotate camera it no longer goes in the same direction.
