Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
On create new file
5 REPLIES 5
etfrench
319 Views, 5 Replies
On create new file
Is there a way to run a script whenever a new file is created?
ETFrench
5 REPLIES 5
in reply to: etfrench
I'm not too familiar with the way Fusion does its events but you might start with the Application object and this example (Sample Programs/General/Miscellaneous/Application Event API Sample). The application object help page is here), and I'm assuming those links are persistence given I've had trouble getting back using Firefox history.
The Application object has documentOpened and documentOpening event handlers. Whether that's the same thing as "create new file" I don't know. Possibly not...
etfrench
Thanks for the reply.  DocumentOpening isn't the same as creating a new document.  If there were an event for document creation, a script could be created to set parameters and other settings for group projects.
ETFrench
ekinsb
There currently is not a specific event for when a new file is created.  However, we will be adding this in the near future along with some other document related events.
Brian Ekins
Mod the Machine blog
etfrench
in reply to: ekinsb
Sounds good.  Thanks
ETFrench
ekinsb
Just to let you know that this capability will be in the May 30 Fusion 360 update.
Brian Ekins
