Observer
Moving Existing Points in an existing sketch
88 Views, 5 Replies
3 weeks ago
There is plenty of examples that create new sketches and points.
Looking for some sample code on how to move an existing spline point in an existing sketch. This could be really useful for editing existing sketch geometry instead of always creating new, Like in the Fusion gear program I am always having to create a new component instead of editing the existing on. Thanks,
Autodesk Support
352 Kudos
367 Solutions
Re: Moving Existing Points in an existing sketch
2 weeks ago in reply to: michael.graybar
Here's a very simple program that illustrates the process of moving some points on a spline.  I've also attached the model I used to test this.  The points that the spline goes through are regular sketch points and can be moved and constrained in any way other sketch points can.
def run(context):
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        sk = des.rootComponent.sketches.itemByName('Test')
        spline = sk.sketchCurves.sketchFittedSplines.item(0)
        pnts = spline.fitPoints
        skPnt = pnts.item(1)
        res = skPnt.move(adsk.core.Vector3D.create(-1,2,0))
        skPnt = pnts.item(2)
        res = skPnt.move(adsk.core.Vector3D.create(2,2,0))
        ui.commandDefinitions.itemById('FusionComputeAllCommand').execute()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
Autodesk Support
352 Kudos
367 Solutions
I just realized I was using a pre-production build of Fusion to create the file that I attached so you won't be able to open it.  Here's an equivalent file created with the current Fusion version.
Brian Ekins
2 weeks ago in reply to: ekinsb
I used a similar method to modify a simple sketch based on external data. Works fins. But, I couldn't figure a way to get a geometry update for the loft operation based on the sketch.
In UI mode with fusion: any edits of and root sketch result in a recalculation of the resulting body, once you click the 'finish sketch' button. Is there an equivalent to this, something like sketch.finish() in the API?
Stefan
2 weeks ago in reply to: stefan
is it the
command I need to call to trigger a complete update?
Looks bit like.
Highlighted
Autodesk Support
352 Kudos
367 Solutions
Yes, that is forcing a recompute.  I wasn't sure if it would be needed but found that it was after some testing.  We'll expose this as a method in the API in the future instead of making you execute the command.
Brian Ekins
