Good morning all,
Are there methods in the API equivalent to any of the following commands in the UI, which apply to linked/referenced occurrences (occurrences where isReferencedComponent is true):
1. Break link
2. Choose version
3. Get latest version (either at the occurrence level or at the document level, as in get all latest)
Thanks in advance if anyone can point me in the right direction, or confirm that those methods don't exist (and I'm not just overlooking them in the documentation).
Solved by liujac. Go to Solution.
I guess this functionality is still not available? Because this would be really usefull for me.
Cheers,
Orville
Same here, looking for the same thing. It appears "Break Link" was available since Sep 2017, but I can't find functionality for the other two.
Actually, just found one for "get updates" https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-6F1927B4-B34D-463A-A0B3-BE338309DA06
