Hi guys,
is it possible to develop Javascript addins in Visual Studio with working Intellisense on Fusion API objects? Trying to configure it for some time, but with no success.
Thank you very much!
Solved by richter. Go to Solution.
Figured it out finally. Add references to the header of addin js file like this:
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\application.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\dashboard.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\geometry.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\materials.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\userInterface.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\bRep.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\components.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\construction.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\features.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\fusion.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\meshBody.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\meshData.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\sketch.js" />
