I'm experimenting with different uses of the interference calculation in Fusion 360.
One example I'm trying to create is generating the interference of an interfernce body. For example if you create a venn diagram with 3 triangulated circles you get an interior intersection of the 3 circles and 3 outer portions that are the intersection of only two models. I try to create this using this code (below) but I get a InternalValidationError. What is causing this error. I have similar issues in other scripts wheverer I try to calculate and interference multiple times.
def run(context): ui = None try: global app app = adsk.core.Application.get() global ui ui = app.userInterface # Create a document. doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType) product = app.activeProduct design = adsk.fusion.Design.cast(product) design.designType = adsk.fusion.DesignTypes.DirectDesignType # Get the root component of the active design. rootComp = design.rootComponent features = rootComp.features # Create sketch circle on the xz plane. sketches = rootComp.sketches sketch = sketches.add(rootComp.xZConstructionPlane) sketchCircles = sketch.sketchCurves.sketchCircles centerPoint = adsk.core.Point3D.create(0, 0, 0) sketchCircles.addByCenterRadius(centerPoint, 10) # Create a collection of entities for extrude entities0 = adsk.core.ObjectCollection.create() entities0.add(sketch.profiles.item(0)) # Create a cylinder with ExtrudeFeature using the profile above. extrudeFeats = features.extrudeFeatures extrudeFeatureInput = extrudeFeats.createInput(entities0, adsk.fusion.FeatureOperations.NewBodyFeatureOperation) extrudeFeatureInput.isSolid = True extrudeFeatureInput.setDistanceExtent(False, adsk.core.ValueInput.createByReal(2.5)) extrudeFeature = extrudeFeats.add(extrudeFeatureInput) # Create second body to do interference sketch = sketches.add(rootComp.xZConstructionPlane) sketchCircles = sketch.sketchCurves.sketchCircles centerPoint = adsk.core.Point3D.create(5, 0, 0) sketchCircles.addByCenterRadius(centerPoint, 10) entities0.clear() entities0.add(sketch.profiles.item(0)) # Create a cylinder with ExtrudeFeature using the profile above. extrudeFeatureInput = extrudeFeats.createInput(entities0, adsk.fusion.FeatureOperations.NewBodyFeatureOperation) extrudeFeatureInput.isSolid = True extrudeFeatureInput.setDistanceExtent(False, adsk.core.ValueInput.createByReal(2.5)) extrudeFeature = extrudeFeats.add(extrudeFeatureInput) sketch = sketches.add(rootComp.xZConstructionPlane) sketchCircles = sketch.sketchCurves.sketchCircles centerPoint = adsk.core.Point3D.create(0, 5, 0) sketchCircles.addByCenterRadius(centerPoint, 10) entities0.clear() entities0.add(sketch.profiles.item(0)) # Create a cylinder with ExtrudeFeature using the profile above. extrudeFeatureInput = extrudeFeats.createInput(entities0, adsk.fusion.FeatureOperations.NewBodyFeatureOperation) extrudeFeatureInput.isSolid = True extrudeFeatureInput.setDistanceExtent(False, adsk.core.ValueInput.createByReal(2.5)) extrudeFeature = extrudeFeats.add(extrudeFeatureInput) # Create a collection of bodies bodies = adsk.core.ObjectCollection.create() for body in rootComp.bRepBodies: bodies.add(body) # Create InterferenceInput interferencInput = design.createInterferenceInput(bodies) # Analyze interference results = design.analyzeInterference(interferencInput) results.createBodies(True) intersection = rootComp.occurrences.item(0) newBodies = adsk.core.ObjectCollection.create() for body in intersection.component.bRepBodies: newBodies.add(body) #get next level of interference interferenceInput0 = design.createInterferenceInput(newBodies) results1 = design.analyzeInterference(interferenceInput0) results.createBodies(True)
Solved by frankzhang. Go to Solution.
In the mean time is there a work around that would could calculate the interference of these bodies?
One workaround is to add two lines in your code as shown below in red:
del interferencInput
del results
newBodies.add(body)
results1.createBodies(True)
Thank you that seems to work. Unfortunatly it does cost the data in results but I suppose I can save that to other data fields if I need it.
