Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How do you convert a Fusion360 model to a script
1 REPLY 1
pat.callahan1
326 Views, 1 Reply
Is it possible to export a Fusion 360 model to a script?
1 REPLY 1
ekinsb
in reply to: pat.callahan1
Fusion does not currently support this capability.  However, Fusion does support the ability to query the model through the API so technically it should be possible for someone to write a script that would query the model and then create a script that would re-create the model.  It wouldn't be trivial to write and there would be a few fringe cases where you can't get everything you need through the API but I think it should be possible for most models.
Brian Ekins
Mod the Machine blog
Autodesk DevCon in Munich May 28-29th
