Is it possible to export a Fusion 360 model to a script?
Solved by ekinsb. Go to Solution.
Fusion does not currently support this capability. However, Fusion does support the ability to query the model through the API so technically it should be possible for someone to write a script that would query the model and then create a script that would re-create the model. It wouldn't be trivial to write and there would be a few fringe cases where you can't get everything you need through the API but I think it should be possible for most models.
