I was wondering how to delete a post if you want to. Is that possible?
Solved by herzinj. Go to Solution.
Hi Dirk,
I don't think that it is possible for you to delete a post once you have created it, though I think you are able to edit it. There is a little drop down icon at the top of your post that will tell you your options. If you end up wanting a post deleted, please contact Moderator@autodesk.com
James
Use the options dropdown and select Report and ask for the post to be removed by the moderator.
Mark
Mark Hughes
Owner, Hughes Tooling
test comment
Do you find this information helpful? "LIKE" this answer! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цьому повідомленню!
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button. | На ваше запитання відповіли? Натисніть кнопку 'ПРИЙНЯТИ РІШЕННЯ'.
Olena Rubin
Technical Support Specialist Autodesk | Фахівець Технічної Підтримки Autodesk
